586,082 active members*
3,873 visitors online*
    Is a timer relay what I need???
    I've got a Colombo spindle that has a 220v fan that is independently powered from the spindle motor itself.
    Per the manual, the fan should be on at all times. That seems to be a bit of overkill, at least in a non-production environment.
    I'd like to trigger the spindle fan to come on when the VFD powers up the spindle and delay the shutdown of the fan for a few (5-10) minutes after the VFD powers down the spindle to allow for cooling.
    Is a timer relay what I need? Something like a Wieland KZT 510 K??
    Thanks!
    Dec 2013
    5717
    Re: Is a timer relay what I need???
    That would do it. Any Off Delay relay with the proper voltage and time range would do it.
    Jim Dawson
    Sandy, Oregon, USA
    Thanks Jim! Now I just need to figure out the wiring aspect.
  1. Replies: 12
    Last Post: 01-30-2023, 01:23 PM
  2. Relay timer for solenoid.
    By moto52000 in forum CNC Machine Related Electronics
    Last Post: 12-04-2011, 06:54 AM
  3. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  4. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  5. Electronic relay Timer Question
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2009, 04:56 AM
