586,121 active members*
3,643 visitors online*
    Jun 2003
    Unhappy Mazak C axis programming
    I just need an advice from a Mazak user concerning programming C axis in EIA mode. Usually, we use Mazatrol language with no problem but when I use MasterCAM to generate C-axis programming the C axis start jogging within the toolpath. As an example, I have join a sample file of 1 inche square on the face of a part. What is wrong with this program.
    Attached Files Attached Files
    Jul 2005
    i can't directly see the problem in your program , but maybe you need to add the G17 code witch is used to select the working area ?
  1. Mazak 8G M/C,mazatrol eia-t, z axis stuck
    By imwllc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2009, 04:48 PM
  2. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  3. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  4. 4th axis programming
    By smoggy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2005, 05:16 PM
  5. 4 and 5 axis programming
    By Cammotion in forum G-Code Programing
    Last Post: 03-03-2005, 06:39 AM
