587,030 active members*
3,689 visitors online*
    Jun 2018
    CNC 3040 & Arduino CNC Shield?
    I recently purchased a Chinese CNC 3040. All the documentation says it'll work with Windows using Mach3, however I do not have access to a windows machine.
    My current plan is to build a control box using a switching power supply and an Arduino CNC shield v3.
    I'm new to this forum, but I have noticed that there's an issue with replacing the spindle VFD. So, my initial plan is to run the spindle from the original controller with the manual spindle speed.
    Any experience with such a setup? Any gotchas I should be looking for?
    Thanks.
    Jun 2014
    5
    I have actually done this, I actually did it a while ago but only got it set up today and I'm really pleased with the results. My spindle controller does not support pwm so for the moment I have to control it manually. However I found grbl very easy to set up.
  1. Poor output from Arduino CNC Shield v3
    By mike0866 in forum Arduino
    Last Post: 10-13-2015, 06:46 AM
  2. 3020T Arduino + GRBL + CNC Shield V3 Conversion
    By metropolicity in forum Chinese Machines
    Last Post: 09-07-2015, 02:42 AM
  3. Motor/Stepper/Servo Shield for Arduino
    By steamboatmodel in forum Open Source Controller Boards
    Last Post: 11-18-2013, 07:36 PM
