586,052 active members*
4,326 visitors online*
Results 1 to 9 of 9
    May 2012
    12
    problem with firmware Update
    Dear Sir:
    I have a problem with firmware Update MK3/4 planetCNC, Please help what I do.
    See picture in the attachment.
    Mar 2017
    1312
    Re: problem with firmware Update
    Please disconnect controller from power supply and connect it back. This error indicated that update was completed but controller somehow did not "leave" bootloader mode. This should be OK after you connect power and USB back with controller.
    May 2012
    12
    dear sir,
    I did like what you said, but gives the same problem.
    May 2012
    12
    dear sir,
    Mar 2017
    1312
    Try this:
    ?Please use external power supply for controller!
    - Exit software PlanetCNC TNG
    -turn off and disconnect controller, meaning disconnect power supply and USB cable. Controller needs to be completely without power and connection.
    -Connect power supply and USB with controller
    -Again start PlanetCNC TNG software and update FW.
    Please be persistent...
    May 2012
    12
    hello sir,
    I did exactly the steps you gave me.
    but it is still the same problem.
    May 2012
    12
    Dear Sir.
    I worked the same steps,but gives the same problem.
    May 2012
    12
    hello sir,
    Please reply to this problem
    I am waiting for you to reply
    Apr 2018
    45
    Quote Originally Posted by suli25an View Post
    hello sir,
    Have you tried emailing support? I've found more success with the support group rather than relying on a response from this forum.I believe the support email is on the planet CNC website.
  1. Firmware update
    By bee2606 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-19-2016, 09:58 AM
  2. GM215 Firmware Version Check/Update Support
    By interflexo in forum Gecko Drives
    Last Post: 01-28-2016, 10:09 AM
  3. Problem after update
    By Diverdude in forum SheetCam
    Last Post: 01-17-2014, 03:57 AM
  4. Leetro Firmware update
    By lfe011969 in forum Redsail Laser
    Last Post: 02-04-2012, 12:32 AM
  5. DLL not match Firmware version problem
    By gsar10 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2010, 10:13 PM
