Hi i am new to cnc i have been trying to write a program for an okuma mcvII bridge mill we have at work this is a relatively simple program for face milling hr plate to dcf we process 4x12 foot plate with 8” face mills our toolchanger dose not work so tooling is swapped manuelly.
The controller is a OSP-U100M
The manuel i have is publication # 4186-E dated march 1998
The basic program structure is to set xyz at one corner have the operator give length and width and have the program cut only on the x axis feed starting at tge outer edges and working to the center then stopping.
I have all the code wrote out and was trying to use a simple if statement and 6 varribles to govern the loop and table travels.
The code will run all my movements flawlessly in a g code simulater but on my controller it will not move to the line i address in the code
The error given is if goto statement address not found
My varriables are set as vc1=1 all as seperate blocks vc4 is my loop counter and vc5 is the quantity of passes required to mill the plate
My numbering system for the entire 48 lines is as follows
N01 g20g90
N02 some g code
N13 Loop starts here
N42 IF [VC4 LE VC5]N13
N48 M30
This is the syntaxt and grammer shown in the programming manuel we have for the machiene.
Please someone tell me i am making a total noob mistale somewhere my addresses match why caint the controller find the N13 address?
Du
