586,076 active members*
3,702 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2009
    135
    Torq Cut 22 Spindle drive fault
    Does any on know what the F602 fault is?
    I keep getting an axis drive fault. When I do get the axis to stay on and turn on the spindle I can here it varying the rpm. I can also see this variance in cut it is making.
    Any suggestions on isolating the error. I would hate to send the drive off and find out it is the Motor.
    Any help is appreciated. I have a large job to get out the door. I am dead in the water until I get this repaired.
    15362
    Re: Torq Cut 22 Spindle drive fault
    Quote Originally Posted by cooperjm View Post
    The F602 is a lost phase, how are you powering your machine
    Mactec54
    Sep 2009
    135
    It is being run from single phase power. Has been running for over a year this way with no issues.
    15362
    How do you have it connected, there is a right way and a wrong way to do this
    Mactec54
    Sep 2009
    135
    Another clue...yesterday I was tapping large threads and stalled the spindle a couple of times. The mill ran normal all day after that with no issues.
    The voltage coming into the VFD is 247.
    Sep 2009
    135
    The line in blue shows the changes that I made.
    Sent from my SM-G955U using Tapatalk
    15362
    So you have Power on L1 and L2 is that correct
    Mactec54
    Sep 2009
    135
    Yes sir. It has been running well for over a year in this configuration.
    Would switching phases at the vfd tell us anything?
    15362
    No you can not switch any Phases, R and S are the correct main power supply connection for the VFD Drive
    That's not a good idea to show people that you are using a white wire for a Power wire, this is a code violation
    At the VFD Drive you need to remove T terminal wire and tape it off. Then jumper R to T Terminal this will get rid of the F602 if you don't have any damage to the VFD
    You must run your machine with this in your mind that you will have more than 1/3 less Hp, running on single phase, if you stall your spindle motor you will do some expensive damage, I still have some parts for these machines new VFD Drives Etc
    Mactec54
    Sep 2009
    135
    As I said earlier. I stalled it a couple of times yesterday. This is probable why I am having issues today.
    I did as you said and removed the T wire at the VFD and jumped R and T. As soon as I turn on axis drives I get and axis fault. So I would assume that the drive is damaged.
    In all the reading of making this machine run from single phase I do not remember instructions to jump R&T.
    What is the cost for a VFD from you. Are you affiliated with EMI?
    15362
    No we are not affiliated with EMI
    When you say you have an axis drive fault which axes
    Mactec54
    Sep 2009
    135
    After turning on machine an enabling axsdrv I get this error. Sometimes it will wait a minute or two before erroring.
    I had the spindle running one time when it errored and it didn't apply the brake.
    15362
    Ok remove the Jumper and we will do it another way, Remove the original jumper that you put in
    The L3 line to the VFD T connection can be put back on
    Remove the L3 Fuse
    Now Jumper L1 to L3 at the power input, make sure you remove the Jumper you added when you first run your machine
    Mactec54
    Sep 2009
    135
    Wouldn't swapping the lines on the vfd have the same effect?
    15362
    No it would not, you can not change R and S
    Mactec54
    Sep 2009
    135
    This is how it has been connected for the past year. No issues until the other day. I have a single phase coolant pump so no modifications were needed there.
    Do I need the jumper from R to T in the VFD?
    Attachment 399908
    Dec 2005
    504
    It can be more than a lost phase. If it has been working for a year, and/or is intermittent it's likely a loose connection or distorted power. It's summer and everyone's AC units are running hard. Depending on your location voltages can be swinging wildly during the day. If you try in the middle of the night does it behave?
    See page 208 of the manual.
    https://www.yaskawa.com/delegate/get...IE-S626-6C.pdf
    Attachment 399914
    15362
    Attachment 399908
    Yes if you connect it the way you have, your jumper, it will help with fooling the phase detection
    The other way I suggested is you don't need your jumper in Green or a jumper at the VFD only one Jumper is needed L1 to L3 this will do the same as what you have without the need to have a jumper at the VFD, so all the wiring would stay the same
    Mactec54
    Sep 2009
    135
    I ran jumper on the fault circuit for the VFD then turned on the machine. With the jumper in place I do not get the axis fault. Also if I hold in the VFD contractor while enabling the drives I still get the 602 error.
    I am confident that the VFD is bad. We will know in a couple of days when the replacement arrives.
    Sep 2009
    135
    Mactec54
    My machine has circuit breakers not fuses.
    Could you draw on the schematic the way you would wire it up. That would take the confusion out this.
    Thanks for the help.
Page 1 of 2 12
  1. Bridgeport torq-cut 22 1997 axis drive fault
    By CSOSA in forum Bridgeport / Hardinge Mills
    Last Post: 05-09-2014, 01:42 PM
  2. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  3. Spindle Drive Fault
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2010, 02:24 PM
  4. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  5. Spindle drive fault
    By Peat in forum Cincinnati CNC
    Last Post: 11-08-2008, 08:02 AM
