586,072 active members*
4,620 visitors online*
    Jan 2018
    RNR Mach3 Motion Control Card - MPG connection
    I have a Chinese 3040 cnc machine controlled by a RNR usb Mach3 motion control card. This card has a 10 pin socket for an mpg pendant control. Can anybody list the pinouts of this socket or explain how to connect the mpg to it?
    Feb 2019
    Quote Originally Posted by CrazyJane View Post
    This may help
    The following describes each pin:
    5V positive, 5V negative: Provides a DC 5V power supply, which can be used to power the handwheel
    X-axis, Y-axis, Z-axis, A-axis: Connect to the axis switch on the handwheel, use
    To select the axis to be jogged
    A and B: encoder outputs A and B connected to the handwheel X10: Increase the handwheel speed by 10 times
    X100: Increase the handwheel speed by 100 times
    The handwheel interface is compatible with the Weihong system handwheel.
    Apr 2019
    Re: RNR Mach3 Motion Control Card - MPG connection
    this does not provide the pin and port numbers that Mach3 needs to configure the input pins.
  1. YOOCNC M3-USB-JB4 Motion control card not recognized by Mach3 software
    By cnc_magic in forum Machines running Mach Software
    Last Post: 06-17-2020, 02:33 PM
  2. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  3. Mach3 Usb Motion Control Card
    By liron in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2014, 10:40 AM
