586,110 active members*
3,358 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa SGDH start up issues - jog not working - no alarms - where to start?
    Jun 2005
    30
    Hey all,
    I recently purchased a used Yaskawa drive and motor, new encoder cable and new motor power connector. After getting everything reset and hooked up, I am having some difficulties getting it to jog. When i try to jog, the motor will either hum and not move, or will oscillate violently between maybe 90° to 120°. It's pretty sporadic. The drive does not produce any alarms, unfortunately, so I'm a little unsure where to start the diagnosis. This is my 9th Yaskawa/motor drive setup, so I have a little experience with these. I have never had an issue at this stage in the game, but this is by far the largest motor I've dealt with to date (all others have been .2KW-1.5KW ). Any help would be much appreciated.
    All the parts I bought were listed as operational. The motor is the odd ball in the group, but nothing is jumping out saying it shouldn't work in this setup.
    Some info on the setup:
    specifications
    Drive: SGDH-50AE: Nothing special to note on the drive. Not shipped with a fragile sticker, but was well packaged.
    Motor: SGMGH-40A2B61: The motor is a strange breed. It is listed as 4KW, but the standards for this motor are 3KW or 4.4KW. The rated RPM is 1000RPM instead of 1500. The motor shaft is 1.673" dia instead of 1.378", and it has the next size up power connector. Other than that, it looks very good cosmetically and the shaft spins smooth when not powered. This wasn't shipped in the best manor for something of this size, just a few extra pieces of cardboard on each side in a box and no fragile sticker (motor weighs maybe 50 lbs.)
    Motor Connector: Cannon MS3108E32-17S. I couldn't find a cable assembly unfortunately, so I had to make my own with limited soldering capability for this size of connector. I've inspected the solder joints after these issues, and everything appears to be solidly connected still. I also tried disconnecting a motor power line between drive and motor, but this does produce an error code on the drive, so i'm assuming power supply isn't the issue.
    Encoder cable: Import - no part number listed, but specified for SGMGH-30ACA6C servo motor and fits my motor and drive correctly. Not sure why the connector has around 20 pins that only go to a 6 pin cable, but i'm assuming this came wired correctly. Haven't looked into this as of yet. Also, when I first got the drive, i tried hooking up a SGMAH-04 motor to it, and got an "incompatible encoder" error, and since this one gives no error, i assume it's working ok?
    A couple of random questions while I'm at it:
    1. Why does Yaskawa have a 19ish pin connector on the motor going to a 6 pin connector on the drive.
    2. Way off topic maybe, but my line voltage is 241, 237, 235, and each line to ground voltage is 117, 212, 120. Is that normal (with or without a rotary phase converter?). I've also got another 3 phase input drive going and it doesn't have any issues running, so don't think this is an issue, just curious.
    Appreciate any help and insight anyone could provide!
    -Brian
    Jun 2005
    30
    Re: Yaskawa SGDH start up issues - jog not working - no alarms - where to start?
    I found the culprit of the issue, and unfortunately, it was my shoddy craftsmanship. Looks like i had some extra flux on the cable plug that I soldered up. Strangely, the cable was testing fine by itself, and the motor was as well, but when the two where connected, i was getting around 2.6Mohm's resistance between wires on the free end of the cable. Guessing the pressure exerted when connected was squeezing flux into places it shouldn't have been. After some extensive cleaning, everything appears to be working well now. Thanks everyone for taking a look at this.
  1. Replies: 2
    Last Post: 12-18-2023, 08:32 AM
  2. Yaskawa SGMG and SGDH
    By stang623 in forum Servo Motors / Drives
    Last Post: 10-02-2012, 07:40 PM
  3. Replies: 6
    Last Post: 12-03-2011, 01:27 AM
  4. Yaskawa Servopak SGDH
    By empireweld in forum Servo Motors / Drives
    Last Post: 01-03-2010, 04:44 AM
  5. YASKAWA SGDH-30DE
    By vipinsumitha in forum Servo Drives
    Last Post: 12-07-2009, 03:56 PM
