586,983 active members*
3,682 visitors online*
    Mar 2018
    68
    spline spindle lock
    I made this spindle lock for x2.7, lms 5500, or G0836, looking for any feedback folks might have to offer
    https://www.thingiverse.com/thing:3049832
    https://youtu.be/QMmzyp-AdEI.
    Dec 2013
    158
    Re: spline spindle lock
    Very Cool. I don't have audio so I can't tell if your saying anything or not. Will it be spring loaded to the open position?
    Mar 2018
    68
    It cams enough that you need something to keep it from pushing the pins out and rotating the top. I was thinking of a thumb lever that would lock it open or closed. I don't think i'm going to try to put a spring on the rotation.
    Nov 2005
    222
    Nice work on that mechanism.
    If you are not going to have spring to unlock the spindle when you take you hand off then I would definitely add a switch to disable the spindle while lock. When I was building my spindle lock I thought to myself I won't forget and leave the lock on when I try to start the spindle. Well put the switch on anyway and I'll bet a hundred time I've turned the spindle on and when It doesn't come one I look up and the lock is on.
    This is what I did. The safety switch is a reed switch stuffed in a hole in the base plate. There is a rare earth magnet mounted in the bottom of the lock ring. I wired it into the enable circuit of the speed control on the mill. When the magnet is over the reed switch the spindle will run.
    I gave up trying to get the pictures to load correctly/
    Unlocked
    Attachment 400056
    Locked
    Attachment 400054
    Safety switch
    Attachment 400058
    John
    Dec 2013
    158
    Nice spindle lock!
    Quote Originally Posted by rcheli View Post
    Unlocked
    Attachment 400056
    Locked
    Attachment 400054
    Safety switch
    Attachment 400058
    John
  1. spindle lock
    By ShawnT in forum Spindles / VFD
    Last Post: 06-02-2015, 05:54 PM
  2. Spindle lock
    By Larry Myers in forum Sharp CNC
    Last Post: 06-16-2010, 04:04 AM
  3. Spindle Lock for SX3
    By Old Megawatts in forum Syil Products
    Last Post: 05-01-2007, 11:19 PM
  4. Stationary spindle motor using ball spline?
    By GalaticDan in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2005, 01:59 AM
  5. Stationary spindle motor using ball spline?
    By GalaticDan in forum CNC (Mill / Lathe) Control Software (NC)
