586,530 active members*
3,097 visitors online*
Results 1 to 13 of 13
    Apr 2013
    110
    TNG: Input configuration
    Goodmorning everyone,
    With TNG software how can I configure the inputs? both those on the MK3 / 9 card and those on the EXTIN card?
    I only managed to configure the two probe inputs and that's it. I can not find the "Input" and "ExtIn" section in the setting menu
    Thank you
    Attachment 400014
    Attachment 400016
    Mar 2017
    1316
    Re: TNG: Input configuration
    TNG for now does not support this option.
    Apr 2013
    110
    Ok, thanks for the reply.
    My electrical panel is configured to use the extIn and extOut cards so, for now, I will still use the USB CNC software which, for my needs, I consider mature and stable. As long as the management of input and output cards will be implemented in TNG, I will try to learn how to write the scripts.
    Apr 2007
    1955
    Would you mind posting the scripts that you are writing? We are just getting started with the mk3/9 and TNG.
    Apr 2013
    110
    Hi, I'm sorry for my bad english ...
    In truth I have not yet written anything, I hope I can do it as soon as I have the time .... unfortunately, after returning from the holidays there is a lot of work to do and free time is missing.
    When I used Mach3, I had written some probing macros that I miss in USB CNC (operations that I can do also with the software of Planet but are manual and boring).
    In any case, even if TNG misses some things that were with the "old" software, there's everything you need to get started (and even more).
    Good work and, I hope, have fun.
    Mar 2017
    1316
    Most useful probing macros are included in TNG. If you have something specific you can easily implement yourself. What are you missing?
    Regarding input configuration - see Settings/User Interface/Shortcuts. You can assign shortcuts to all input pins.
    Apr 2013
    110
    Yes, in fact now with TNG I can create custom scripts (and I'll do them as soon as I have the time); the automatic probing that I miss the most and the possibility to detect any angle as in the attached image; it often happens to me that the standard angle can not be detected for workpiece clamping brackets or other obstacles.
    For the configuration of the inputs I saw what you say (thank you) but is limited to the first 8 (those on the main board) and, for now, it is missing the management of extra inputs that I'm using.
    Attachment 400872
    Apr 2012
    91
    mar-cone - You had me about to jump on my PC I stupidly thought that TNG had been given some useful graphic addons.
    Forlorn hope.
    Apr 2013
    110
    puoi fare qualcosa del genere da solo .... basta armeggiare con script e pulsanti personalizzati .... sul blog viene spiegato come fare
    Mar 2017
    1316
    I will add "graphic addons" to our TODO list.
    Apr 2013
    110
    Great news!
    Apr 2012
    91
    I love the TNG software. But I am quite an old guy already.......
    Mar 2022
    13
    Here is the most effective way to get outcome in Microsoft Azure Fundamentals AZ-900 accreditation test to make progress in the IT calling. You simply have to invest a great deal of amounts of energy and time to get the Microsoft Azure Fundamentals test cleared. On the off chance that there could be no appropriate preparation or technique, we may not deal with anything. The principal thing that comes to one is to have a legitimate Microsoft AZ-900 test questions asset which can rather than disarray can assist with getting outcome in AZ-900 Microsoft Azure Fundamentals test. These days, Examsleader Microsoft AZ-900 practice exam dumps is solid and one can without much of a stretch trust on and use this proposal to clear the AZ-900 Microsoft Azure Fundamentals test. .
  1. Pin Configuration
    By Jmooresshop in forum Okuma
    Last Post: 07-10-2015, 12:50 PM
  2. cnc configuration
    By nitroboy in forum Stepper Motors / Drives
    Last Post: 10-31-2010, 09:56 AM
  3. Replies: 1
    Last Post: 07-12-2010, 01:45 PM
  4. Bad I/O bus configuration
    By whitemanager in forum Controller Cards
    Last Post: 05-10-2010, 02:46 PM
  5. MACH 3 USB INPUT CONFIGURATION
    By coremfg in forum Machines running Mach Software
    Last Post: 01-08-2008, 03:04 PM
