587,047 active members*
2,503 visitors online*
Results 1 to 7 of 7
    Jul 2015
    11
    Question Stopping macro Issue
    Hello! :wave:
    I´m writing a macro that have several steps and inform the user with a message on the status window on each step of the process.
    If the macro is stopped with the ESC key or the STOP button, the movement stops but the macro still writing the messages on the status windows and keep running without movement.
    My issue here is that every step of the macro it have a variable that is changing while its running so if the macro is stopped that variable will serve as a reference to tell the user where the macro was stopped.
    I have the
    if(!exec.Ismacrostopped())
    but the ELSE statement only run after the whole macro finish running and give the message that the macro was stopped but only after all the routines went thru.
    It isn't suppose that if you stop a macro it will go to the if(!exec.Ismacrostopped()) directly???
    I´m running the macro from a button BTW.
    Any help would be appreciated.
    Thank you in advance!
    Jun 2015
    943
    Re: Stopping macro Issue
    C# do ordinal code execution just like most other programming languages.
    I think you don't fully understand how to code in C#, but maybe we can help if you post your code and describe the issue a bit more detailed.
    Jul 2015
    11
    Quote Originally Posted by OlfCNC View Post
    I do understand how C# works, what I don´t understand is why when i press stop or the esc key the macro only stops the axis movements but the macro is still running all the way thru the end instead of just stopping.
    All the macro runs fine, all the routines and variables (its very extensive) my only problem is that the macro wont stop.
    Mar 2010
    813
    ESC will stop all movement but macro will continue...Try
    if(exec.Ismacrostopped()){return;}
    else{MessageBox.Show("????");}
    Jul 2015
    11
    I found someone with a similar issue as me and here are some possible solutions in case anyone needs them
    https://forum.cncdrive.com/viewtopic.php?f=4&t=1197
    Thank you!!!
    Jul 2015
    11
    Quote Originally Posted by Dan911 View Post
    Yep I´m using that solution now Thank you Dan911 , lots of IFs on the code until they fix the Stop issue. =)
    Mar 2010
    813
    There really wasn't a fix issue, a macro is a thread and shouldn't be canceled while running. That's why the functions ismacrostopped and ismacrorunning was added.
  1. Set G30 macro issue
    By dcrace in forum Daewoo/Doosan
    Last Post: 05-15-2024, 11:06 PM
  2. Issue with macro variable #3002
    By grweldon in forum Fanuc
    Last Post: 01-18-2018, 06:58 PM
  3. Possible issue with Mach3 Mill losing axis zero when stopping during arc moves
    By qbit in forum Mach Software (ArtSoft software)
    Last Post: 04-23-2016, 04:43 PM
  4. Infuriating issue with Mach 3 is stopping CNC joy...
    By Farasien in forum Charter Oak Automation Support Forum
    Last Post: 02-08-2015, 04:34 AM
  5. Random Stopping - E-Stop Issue
    By EvanZ in forum DIY CNC Router Table Machines
    Last Post: 11-07-2008, 08:57 PM
