586,058 active members*
3,586 visitors online*
IndustryArena Forum > Hobby Projects > RC Robotics and Autonomous Robots > NEW AMADA EG-AR 6013 PRESS BRAKE ROBOT
Results 1 to 7 of 7
    Anyone have experience with this new machine or its AR-CAM software? it seems fairly buggy but ive only been using it for a month or so.
    Re: NEW AMADA EG-AR 6013 PRESS BRAKE ROBOT
    attached picture
    Oct 2008
    27
    I worked with an Astro 100NT/HDS for seven years starting in '07 using AstroCAM. It was buggy as well, but you get used to it. Just be patient and you'll get the hang of it. I made sure to report every error, bug and hiccup it made.
    the main problem im having it when it picks a part up with suctions it will pick up more then one from them being stacked together leading to the parts dropping out of place which then results in a crash. amada has no real solution to this other then a magnet that works sometimes. and im running aluminum right now.
    Oct 2008
    27
    We had lots of problems like that as well. I thought that had a vibe or air blow part separator solution for the newer machines. One method we used was industrial velcro to act as a stripper. We built Heavy metal angles and faced it with the stuff. It would strip off any second parts and with a little creativity in placement, drop the part back into the stack nice as pie. If the parts are very problematic, do you have a vertical rack?
    the vert rack will only hold parts smaller then 6.7in. so most of my parts have to be stacked were trying out brushes right now and slowing the loading process in cam software.
    Oct 2008
    27
    Might also help if you are using a turret with air blow, to turn it off when punching these parts and have the operators wipe the sheets down prior to breaking them out. Had to do that on some 24GA parts that went through the Astro.
  1. Amada RG 80 Press Brake Problem
    By lykinsrobbie in forum Maintenance DIY Discussion
    Last Post: 09-27-2020, 06:22 PM
  2. Amada Press Brake
    By Footballwr46 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:29 AM
  3. Need Help - Amada Press Brake HFBO125
    By komang in forum Maintenance DIY Discussion
    Last Post: 04-08-2018, 05:14 AM
  4. Amada PRESS BRAKE HFT 220-3
    By M7MED in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 03:04 AM
  5. Amada brake press controller nc9 r
    By maplesiport in forum Controller & Computer Solutions
    Last Post: 07-15-2010, 11:32 PM
