Maybe one of you has had this issue before. When I am doing a solid vector cut, all the cuts where the y axis is moving result in the cut not going all the way through, but leaving small perforations. The X axis movement is fine.
I have swapped the stepper drivers and the problem stayed on the Y axis. I believe I have a redsail x700 clone with a "60" watt laser. I have also isolated the stepper motors to their own 24v ps.
Any ideas?
