586,446 active members*
3,266 visitors online*
    May 2004
    41
    Recommended Encoder
    I have r990h boards and Renco CA18 encoders http://www.renco.com/106021.htm (no longer made) but after many reincarnations the pins are starting to be faulty. I want to change them , what is Rutex recommendation on which encoders to use and not to use.
    Regards
    Paul
    Oct 2003
    170
    encoder reccomendations
    US Digital encoders are good and reliable. If you get the single ended encoder, our little R2210 adapters make hook up very easy. You hook up 5 wires to the adapter and plug in a shielded cat5 cable into the drive and the adapter and you are done!
    CUI sells a nice little encoder for motors with 3/8 in shafts and smaller:
    Price is 30.00 from Digi-key corp.
    Part number is AMT-102v, I believe. Be sure to ask for the number for the 1 ft pigtail cable to hook to the R2210 adapter. It is dip switch selectable output between about 32 lines to 2000 or so. It comes with a set of bushings to adapt to many shaft sizes.
    Don't try to make your own cable. It is picky about the correct connector on it. I think the cable is just a few bucks.
    Tom Eldredge
    Rutex LLC
  1. Anyone got any X1 recommended feedrates...
    By digits in forum Benchtop Machines
    Last Post: 10-03-2006, 11:54 PM
  2. Recommended Laptop
    By hugo carradini in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2006, 09:49 PM
  3. Recommended transformer
    By svon89 in forum Hobbycnc (Products)
    Last Post: 05-03-2006, 03:22 PM
  4. Recommended encoder?
    By cnc2k in forum Gecko Drives
    Last Post: 04-12-2004, 01:57 AM
  5. CNC recommended reading?
    By margni74 in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2003, 04:28 AM
