586,069 active members*
3,451 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 15XT z axis move by hand
Results 1 to 8 of 8
    Jul 2018
    5
    Hello all. First time posting in the Fadal area, but I've been a long time lurker during my search for my first vmc. I finally found one (1998 vmc15xt) and won it at auction. However, the machine is now in a warehouse with no power and the counter weight is not pinned. Can I move the z ball screw by hand to lower the head and what would be the best way of doing that.
    Jason
    Sent from my Pixel 2 XL using Tapatalk
    Apr 2014
    345
    Re: Fadal VMC 15XT z axis move by hand
    Take off the z axis way guard and the screw will be exposed I’m not sure if you’ll be able to turn it by hand but you can try.
    Sep 2009
    103
    Yes, If you can get to it. It might be easier to remove the 4 bolts holding the Z motor on and rotating the coupling to lower the head. Use a sharpie to mark how the motor clocks to the ball screw or you'll have to adjust your resolver if you clock it different.( Not a big deal)
    Apr 2014
    345
    Quote Originally Posted by Tedger View Post
    I thought about that but hard to reach in and get a good grip on the coupler.
    Jul 2018
    5
    Thanks guys. Do you know off hand what size the z way cover bolts are? I might try that and see where it gets me.
    Sep 2009
    103
    7/16" - If you drop the way cover, make sure you clean out all the chips packed in the bottom.
    Jul 2018
    5
    Thanks. It looks like the machine was cleaned out very well before being shipped to the auction site. It came out of a GE plant consolidation. Very clean machine. Best one I have seen in my 6 months of shopping around for one.
    Feb 2007
    171
    Grab some gloves and turn the ballscrew. The counterweight makes it easy to turn unless you have a bound up Z axis ballscrew or bearings.
    FadalCNC Tech Support.
  1. Replies: 3
    Last Post: 05-25-2018, 11:40 PM
  2. WTB: Fadal VMC 15XT
    By zekeymonkey in forum Want To Buy...Need help!
    Last Post: 03-09-2017, 01:25 AM
  3. FADAL VMC 15XT for sale
    By choppero in forum Uncategorised MetalWorking Machines
    Last Post: 08-30-2012, 08:38 PM
  4. Fadal VMC 15XT
    By KylieandDany in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2009, 07:07 PM
  5. Fadal VMC 15XT v's Mazak 20/40A M2
    By cam280 in forum Fadal
    Last Post: 06-23-2009, 01:57 AM
