586,067 active members*
4,985 visitors online*
    Mar 2018
    17
    DM2400 Oil/Grease
    I was hoping for some clarification. I have only seen the oil chart and table from bad scans.
    My mill has the manually operated piston type oiler, and calls for Shell 32T. Why are there so many oils listed on the chart? Am I supposed to be oiling other locations on the mill than what is fed by the automatic oiler?
    Also, can anyone recommend a grease for the stepper gears and thrust bearings? Is NLGI 2 the right viscosity?
    Mar 2018
    17
    Re: DM2400 Oil/Grease
    What are you using for way oil? I am assuming most users are using a #2 way oil rather than a #1. Is this correct?
  1. SBR16 bearing truck grease/grease fitting?
    By isaac338 in forum Linear and Rotary Motion
    Last Post: 03-11-2014, 08:08 PM
  2. DM2400 won't run
    By dustin033 in forum Benchtop Machines
    Last Post: 07-01-2013, 04:19 AM
  3. DM2400 & G540
    By Marty_Escarcega in forum Dyna Mechtronics
    Last Post: 01-02-2013, 03:39 PM
  4. New to CNC, what parts to grease and with what type of grease? Wood machine.
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 11-22-2011, 04:45 PM
  5. anyone have postprocessor for DM2400??
    By jayou in forum BobCad-Cam
    Last Post: 02-26-2007, 05:06 PM
