586,082 active members*
3,777 visitors online*
    Jun 2018
    18
    Clear Acrylic is not Acrylic
    Hi guys,
    So I picked up what I thought was some scrap clear acrylic from a makerspace to use as testing at my own workshop. (the laser cutter at the makerspace is broken)
    My first cut with this, I noticed it smells a bit different to the acrylic smell I'm used to (I still need to upgrade my exhaust fan).
    Also, this material releases some kind of oil when cut. This makes me think its not Acrylic at all.
    Any idea what this material could be?
    Jan 2006
    7
    Re: Clear Acrylic is not Acrylic
    Does it have Vinyl adhesive on the sides? Peel that off before you use it... Also, if it has UV stabilizers in it, it can also burn funny...
    Jun 2018
    18
    No vinyl adhesives on it. It had been peeled off already
    I'm hoping it is the UV stabilizers.
    Could it have been a PVC sheet? Any tests to do to confirm?
    Jun 2013
    1041
    Heat a piece of PVC with a lighter and smell it. That will give you something to compare it to. Clear PVC is a hazy blue color. Pretty cool looking and doubtful that's what you have. Realistically there's not a very long list of commonly found options to choose from when it comes to clear plastic. It is almost certainly either acrylic, polycarbonate or petg. They use plasticizers to help in the extrusion process. I'm not a laser guy but the oil is very possibly caused by those additives. Did it come with a film on it? If so was there any writing on it?
    Ben
    Sent from my E6810 using Tapatalk
    Nov 2008
    110
    Clear "hobbyglass" is polystyrene - cheap but quite unpleasant to work with - tends to melt and stick to tools. No idea what laser will do to it.
  1. ISSUE with thermoforming clear acrylic sheets
    By tsamael in forum Vacuum forming, Thermoforming etc
    Last Post: 10-22-2022, 11:41 AM
  2. Can a routers do carving on acrylic clear or other types or better to use blasting
    By videorov in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-02-2017, 07:50 PM
  3. Laser cut clear acrylic 1/2" thick
    By JPMach in forum North America RFQ's
    Last Post: 05-31-2013, 12:26 AM
  4. 50mm thick Acrylic Clear offcuts
    By didja_do in forum Australia, New Zealand Club House
    Last Post: 02-17-2009, 08:26 AM
  5. Clear Acrylic Fender Stratocaster Guitar
    By HygloCompany in forum Glass, Plastic and Stone
    Last Post: 02-17-2006, 06:49 PM
