Even if you upgrade to Aspire, there's no magic button to create a 3D model. It takes a lot of practice, and more importantly, artistic ability and skill to create good 3D models like that.
Gerry, thank you for the reply yes I understand there isnt a magic button. I'm not really concerned about artistic ability. I have a Bachelor's degree in Art, it's been a while since I've sat down & painted. I dont set down & draw much just for the fun of it, but I do draw at least once weekly at work designing signs.
My question is which is the better route having someone make the file or upgrading to Aspire and learn to do it myself
Thank you
I can't answer that. It depends on how valuable your time is, and if you don't mind paying the cost of the model.
Do you know anyone that would create these for me? I'm thinking I'd leave the text & center smooth & flat so I could change those based on the department & badge number.
If they would charge a hundred or so I'll just upgrade & learn to do it myself because I seriously doubt this will be the only one I'll need.
This guy is well known in the Aspire community, and does a lot of custom work.
https://carveddetails.com/
I'd expect it to cost more than $100, but that's just a guess?
But he does have some generic badges for sale for $25.
https://carveddetails.com/product-ca...ymbols/badges/
Michael is very reasonably priced & I'm hoping to do a lot more with him. He already has a lot of the elements made so he is only charging $25 for the badge. I sent him a very intricate design & he quoted $250 for it which I also dont think is bad but I need to get the ok from my customer.
I'm going to order some bits to route the 3d stuff. Can I just use ball nose or do I really need tapered ball nose bits?
What size bits do I need for jobs from 8"x10" up to 12"x18" or so. I have some 1/8" & 1/4" ball nose but no tapered
Thank you
Gary
If the thickness is not too deep, then regular ballnose may work. It depends on how much detail you need. If you fine (small) details, then you need a small tool. Tapered ballnose can be a lot stronger than a ballnose of the same tip size.
And becasue they are stronger, you can often skip the roughing passes and just do a single finish pass with a tapered ballnose.
For really fine details, I like to use 1/16" ballnose, but it'll take twice as long to cut as an 1/8" would.
Ok I've found these on eBay I know they are cheap but I've had a fair amount of luck with some of the cheap china bits.
I've also found some that range in size from .25mm, .5mm, .75mm & 1mm with 1/8" shank.
https://rover.ebay.com/rover/0/0/0?m...2F222674408891
Does anyone have advice on bits for 3d routing? I posted some on my post prior & I'd like some advice.
Thank you
These are very popular in the Vectric community, but are not cheap.
BDP - Cutters
Amana has a large selection of carving bits.
https://www.amanatool.com/products/c...uter-bits.html
Personally, I wouldn't buy that $10 set, but try them and see if they are any good.
Ok thanks for the links. What size(s) should I get?
Depends on how much detail you want. You want to use the largest size that gives you the detail you need, as that will cut the fastest. If you need really high detail, then you want the smallest bits. But of course, with really small bits, cut times go up rapidly.
Yeah I guess I'd want the best compromise of speed & detail but I'm not sure if that's 1/32", 1/16" or something different. I'm sure overall size will make a difference to the detail needed.
Either 1/16" or 1/8" is probably what you want.
Ive purchased a couple stl files on eBay and one is a clock with a bird dog & shotgun, is it possible for someone with Aspire to lengthen the barrel? It's too short.
Thank you
