586,754 active members*
7,492 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Amada Vipros 357 TURRET PUNCH losing reference
    Aug 2018
    Need Help, I have an Amada Vipros with Fanuc 04PC. The machines starts fine but after about 1 hour running the Axis Reference light turns off, I reference the machine again but as soon as the program starts running the light turns off again. Has anyone had this issue too? Please help!
    Mar 2009
    101
    Re: Amada Vipros 357 TURRET PUNCH losing reference
    Quote Originally Posted by Florcampos View Post
    You are most likely getting an emerg stop condition. That will drop NC Ready and Axis Ref led will turn off. You need to isolate the problem. Same place in the program? During X axis movement? Turret rotating? Oil pressure? Etc
    Aug 2018
    I was having issues with the temperature, every time it increased to 50 C it stops in the same part of the program and blocks the machine by turning this light off and I have to turn it off for 4 to 6 hours, then it works fine again. If I turn it off at 45, leave it to cool to 30C this won't happen. Any thoughts?
  1. Amada Pega Turret punch E Stop Reset
    By supreme_hinge in forum Fanuc
    Last Post: 06-12-2023, 01:45 PM
  2. amada turret punch problem
    By bonesclarke in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2019, 07:58 PM
  3. CNC turret punch press(AMADA AC 2510-NT)
    By alimohammad in forum Questions or Problems
    Last Post: 07-13-2017, 05:38 PM
  4. Amada VIPROS 558 Turret
    By Stupidav in forum Fanuc
    Last Post: 04-01-2011, 12:27 AM
