586,108 active members*
3,014 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC Series 18i-MB CF Card Problem
Results 1 to 7 of 7
    Oct 2016
    10
    Post FANUC Series 18i-MB CF Card Problem
    Hello, I have a HWACHEON SIRIUS-UL machining center with the FANUC controller Series 18i-MB. I tried to insert a CF card to backup the memory, however, the machine did not respond. The message shown is along the line of the machine cannot find a cf card. "MEMORY CARD MOUNT ERRROR.HIT SELECT KEY" Could you advise me on how to solve this problem?
    Thanks in advance for any help
    Mar 2017
    314
    Re: FANUC Series 18i-MB CF Card Problem
    how big is the CF card?
    Jul 2017
    50
    I had to partition my card to 256 MB and set as the active partition before I was able to use it on the IPL screen.
    You may also need to name the volume 'FANUC LTD' as you format it as FAT 16.
    Oct 2016
    10
    I use a 128MB Compact Flash card.
    Oct 2016
    10
    Thanks for your advice, I'll try it.
    Size isn't the only limitation on the Fanuc also the type. I have good luck with Compact flash card 256MB (K8034)
    CNC Specialty Store LLC
    CNC Machine Parts & Industrial Supply 5540 State Road 50, STE 101
    Delavan, WI 53115
    P:414-881-4493 F:262-671-0728
    [email protected]
    CNC Specialty Store, Industrial Supply
    Oct 2016
    10
    I see, I'll check it out. Thank you.
  1. Replies: 12
    Last Post: 01-29-2020, 01:46 PM
  2. MPG Handle problem - Fanuc Series Oi-MB
    By PlasmaManZA in forum Fanuc
    Last Post: 04-30-2018, 08:09 PM
  3. Robofil 330F Fanuc System Memory card problem
    By xal3r in forum EDM Discussion General Topics
    Last Post: 04-08-2015, 01:19 PM
  4. Replies: 0
    Last Post: 05-22-2014, 07:00 PM
  5. Fanuc Series O-M Memory Problem
    By ggundrum in forum Fanuc
    Last Post: 04-15-2011, 04:36 PM
