586,463 active members*
3,483 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Transporting VMC-15, How to Secure the Counterbalance Weights
Results 1 to 12 of 12
    i just purchased a 2007 (re-man) VMC-15 and have read the weights needs to be secured for transporting, but i can't seem to find the exact procedure to do this?
    i will keep searching, but any input is appreciated.
    thanks
    Feb 2013
    89
    Re: Transporting VMC-15, How to Secure the Counterbalance Weights
    There are two holes on the side of the Z axis column that line up with two holes on the counterweight. You adjust the height of the spindle head until these holes line up. There should be two pipes with the machine that slide all the way through one side of the column upright then the counterweight then the other side of the upright. I can post pics if this doesnt make sense.
    Quote Originally Posted by NismoGT View Post
    thank you. yes, a photo would be helpful. i do see one hole at the top of the column, but not the second.
    if the weights are not lined up and the machine is not under power, are there options to move the head manually?
    Apr 2014
    345
    Quote Originally Posted by everettengr View Post
    Take off the z cover and spin the ballscrews by hand but I’ll warn you it’s not easy.
    The two holes are right under the arm that holds the atc.
    Feb 2013
    89
    Here are where the holes are:
    Here is the solid steel bar partially in the hole. There are two bars, which is preferable to securing the counterweight, but in a bind, it will work with only one.
    The bar is about 1-3/16 dia and 15-1/8 long.
    Huge help. Thank you!!!!
    I will get these installed before moving the mill.
    It is currently in a riggers shop and the rods are not currently installed :-(
    Hopefully no damage has already been done.
    it looks like i am going to have to make these.
    can you provide the length and bolt hole spacing.
    i am going to meet the trucking company at the riggers and verify everything get loaded properly.
    thanks
    Apr 2014
    345
    thanks
    I just use some 1” heavywall pipe or solid bar. Length ain’t critical about 20” should work. No need for the flanges and bolts.
    Quote Originally Posted by ianagos View Post
    what keeps them in place when driving down the road?
    Apr 2014
    345
    Friction from a couple hundred pounds of counter weight.
    got it :-)
    thanks
    Apr 2014
    345
    got it :-)
    thanks
    Just shipped one from Georgia to Carolina on a trailer without air ride and it made it fine with some random bars that fit through the holes. Make sure it goes through both sides of the column all the way to the electrical cabinet.
    Used a 4x4 to rest the head on.
    Edit to add
    Make sure you do not rest the head on the spindle. I see that so much and it can cause damage to spindle bearings. Also make sure the wood is not pinching any hoses and is sitting on the casting not sheetmetal.
  1. Transporting BMC 20
    By battman in forum HURCO
    Last Post: 02-27-2012, 02:56 AM
  2. X3 Component Weights
    By miseree in forum Benchtop Machines
    Last Post: 11-24-2009, 04:34 PM
  3. Removing backlash on X & Y by using weights?
    By svarzaru in forum Benchtop Machines
    Last Post: 02-24-2009, 02:54 PM
  4. Solidworks line weights in sketch
    By flyingmike in forum Solidworks
    Last Post: 12-10-2007, 07:51 PM
  5. counter-weights
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-15-2004, 03:56 AM
