586,123 active members*
3,454 visitors online*
    Oct 2010
    79
    Fanuc Motor Voltage Question
    I am going to be driving some red top Fanuc motors and I have a question about the drive supply voltage.
    The motor nameplate voltage section varies on all the motors I am using (48V - 127V) but the "PERM. MAG. FIELD" section on the nameplate all say 200V Inverter
    Does this mean I can just use a 200V power supply for all the motors? Or will I need a separate voltage for each motor?
    Attached it an example nameplate
    Dec 2013
    5717
    Re: Fanuc Motor Voltage Question
    The max voltage is set in the inverter. You would run them with a 200 volt class inverter. The real question is: How do you plan on commutating them? Are you using the Fanuc inverters? I went through this a few months ago and gave up trying to untangle the commutation issues and just repowered the machine with DMM servos.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2010
    79
    I have a test motor running already, I used a mesa card to talk to the serial encoder and it can retrieve the commutation data from that.
    I am using a mesa 8i20 to drive the motor, but just with a 48V power supply until I can figure out what the correct voltage to use is.
    So I am still not sure if I should just run 200V to the drives and then limit the current to the nameplate?
    Dec 2013
    5717
    OK, you have the commutation figured out I couldn't use a Mesa card in my system.
    What you propose might work.
    Jim Dawson
    Sandy, Oregon, USA
  1. Fanuc servo motor voltage
    By angaeng in forum Servo Motors / Drives
    Last Post: 11-17-2015, 05:01 AM
  2. Motor Power Supply (-) voltage question
    By beekeep in forum CNC Machine Related Electronics
    Last Post: 03-21-2010, 06:41 PM
  3. Basic Motor Voltage Question
    By pzzamakr1980 in forum CNC Machine Related Electronics
    Last Post: 05-03-2008, 07:26 PM
  4. Stepper motor speed\voltage question?
    By cwdance1 in forum DIY CNC Router Table Machines
    Last Post: 03-28-2006, 11:26 PM
  5. Fanuc model 5 motor voltage question
    By Syp in forum Servo Motors / Drives
    Last Post: 01-24-2006, 02:37 AM
