586,077 active members*
3,644 visitors online*
Results 1 to 6 of 6
    Nov 2017
    4
    60W Laser Engraver Does not cuts uneven way in x axis
    Hello everyone,
    I have a 60w CO2 Chinese laser engraver for a year now, when I got it was ok and cuts evenly, I mean that was cutting a 3mm plywood for example with 20% of power in x axis from 1 to 700 (left & right side of the machine table).
    Recently I discover that needs more power to cut the same plywood for the one side to the other for example till the middle of the table is ok with 20% power after that need more power and at the end fo the table ex. 650mm does not penetrate the plywood is just a line like scratch.
    I try to calibrate again the mirrors but seems ok I believe.
    I don't know what can be the problem, and I need to cut more than 600mm
    Any idea what the problem is ???
    Thanks in advance
    Christos
    May 2004
    402
    Re: 60W Laser Engraver Does not cuts uneven way in x axis
    Have you cleaned the mirrors and lens? I use IPA and a Cotton Bud on mine. Is your extractor working properly or do fumes hang around the cutting area?
    Andrew Mawson
    East Sussex, UK
    Nov 2017
    4
    I did but It doesn't help. Also the extractor seems that is working fine.
    Jan 2008
    940
    have you checked the alignment of the mirrors
    Nov 2017
    4
    I did but I will do it again !
    Nov 2017
    4
    FIXED!!! Alignment of the mirror was the problem.
    Thank you all !!!
  1. Laser burns tiny perforations only on Y axis during vector cuts...
    By jebsmith2112 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2018, 06:17 PM
  2. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2016, 05:57 PM
  3. Uneven Cuts
    By mpa542 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-21-2015, 09:22 AM
  4. Laser cutter/engraver not moving along the Y axis
    By Rick61 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-23-2014, 04:51 PM
  5. CNC'd HF Micromill uneven x and y-axis travel
    By gta18 in forum Benchtop Machines
    Last Post: 01-20-2014, 08:50 PM
