586,036 active members*
4,431 visitors online*
Results 1 to 14 of 14
    Apr 2015
    8
    Fagor CNC800 TG-I Error 064
    Hello,
    I have a problem with Fagor 800 TG-I like this
    The monitor displays Error 064.
    I checked the physical inputs and then displayed the IO status:
    I1 - Emergency Stop =1
    I2 - End Cover SW =1
    I3 - Head Chuck Guard SW =1
    I4 - Saddle Guard SW =1
    Every of Output are OFF.
    Below the scheme IO1 and IO2
    Someone had a similar problem?
    Best refards
    Rafal
    Mar 2008
    169
    Re: Fagor CNC800 TG-I Error 064
    Maybe plc is in stop state
    Carlos Cabrera
    May 2019
    Hello Rafal
    I just bought a lathe and all axis moved perfectly than after a new power up I got the same message and machine will not move.
    Did you sort you problem out and if yes how??
    One another point the attachments are not visible anymore??
    thanks
    regards
    Eyup
    Quote Originally Posted by Rafal-P View Post
    Hello,
    Best refards
    Rafal
    Mar 2008
    169
    Please tell the machine brand and model. Check I1
    Apr 2015
    8
    Hello,
    Unfortunately, the problem is still not resolved.
    It looks like the problem is not hardware. I hope I'm wrong ;-)
    best regards
    Rafal
    Apr 2015
    8
    Hello,
    It looks like the problem is not hardware. I hope I'm wrong.
    best regards
    Rafal
    Mar 2008
    169
    Oh. I was a Fagor Tech. Where is the machine?
    Apr 2015
    8
    Quote Originally Posted by kcho View Post
    Iceland
    Apr 2015
    8
    Iceland
    The CNC 800 TG-I has an I / O1 - 37 Pin and I / O2 - 37 and I / O3 input card installed.
    The documentation shows that the EMERGENCY input is I1.
    In my case, I1 = 1.
    This is how it looks in the input status preview.
    So it looks like the controller sees I1 that it's ok.
    Best regards
    Rafal
    Apr 2015
    8
    Carlos Cabrera
    Hi Carlos
    Do you know how to check it?
    Best regards
    Rafal
    Apr 2015
    8
    Hello,
    Does anyone know how to check the status of inputs I42 - I104 and outputs O25 - 064?
    These are the I / O between PLC and CNC.
    Best regards
    Rafal
    Apr 2015
    8
    Hello,
    Best refards
    Rafal
    Problem SOLVED ;-)
    The PLCI was in STOP mode.
    Apr 2020
    How to put PLCI into RUN mode?
    Aug 2011
    11
    Hello Rafal,
    How did you put it in RUN?
    Regards, Patxi.
    Hello
    I have the same problem.
    How to put PLC into RUN mode?
    Regards
    Daniele
