586,036 active members*
3,477 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Solidcam Error - Can't uncompress CAM-part. Check SolidCAM temporary folder
    Apr 2015
    13
    Solidcam Error - Cant uncompress CAM-part. Check SolidCAM temporary folder
    I save all my SolidCAM parts internally as we are i prototype phase and constantly making small changes to our parts.
    This week, SolidCAM simply stopped opening our CAM parts.
    Solidworks 2017 SP2 4.1
    Solidcam 2016 SP2 HF1
    Help !!!
    I fear i have lost years of work.
    Attached Thumbnails Attached Thumbnails Solidcam Error - Cant uncompress CAM-part. Check SolidCAM temporary folder.png   Solidworks Solidcam Version SP2 HF1.png   Solidworks Version - Solidworks 2017 x64 SP4.1.png
    Jan 2012
    36
    Re: Solidcam Error - Can't uncompress CAM-part. Check SolidCAM temporary folder
    Hello scottbryce,
    I highly recommend you call your local support. One possibly bad cam project will not break or mess with any other cam projects. So you don't have to worry about your other projects. You can start by trying a reinstall over your existing install to see if a file has been corrupted. It will prompt you to repair your previous setup. The other thing I would try is to clean out your temporary folder. to do this, first locate your temporary folder by opening your CAM SETTINGS > CAM-PART > CAM-PARTS TEMPORARY FOLDER. Note where it is pointing. Go to that folder and create a new folder and place all the contents of the CAM-PART temporary folder into the new folder you created. Now try opening a cam project a different cam project to see if it opens.
    Highest Regards,
    Darrin - SolidCAM
    Jan 2012
    36
    Try this.
    https://www.youtube.com/watch?v=aujyfaL_cWA
    Darrin - SolidCAM
    Apr 2015
    13
    All sorted, it seems the hard drive that the temp folder was in was getting a bit "full" moved the temp location to a new drive and solidcam works great now.
    Jan 2012
    36
    Good to hear!
  1. Solidcam programing a part
    By xenon2331 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-12-2018, 04:04 PM
  2. cant get rid of solidcam from a part created internally within the solidworks part
    By Nava in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-24-2013, 01:05 AM
  3. Help me with the SolidCam part I have to do!
    By AIV in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-09-2013, 09:10 PM
  4. Check this out and can Solidcam Do It
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-08-2010, 04:54 PM
  5. solidcam part solving help
    By nero81 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-02-2008, 01:39 AM
