586,106 active members*
3,134 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Plotter file starts with "MK"
    Sep 2007
    5
    Hi all,
    I have this plotter file (.plt) that uses non-standard HPGL commands.
    I don't know its origin or what program has produced it. It is a job file for a Chinese made vinyl cutter.
    I really need to know what these commands are.
    So, here is the file. I removed most coordinates to make it shorter. It does not have any line breaks or white space.
    Code:
    MK4,4,0,0;IN;PA;SP1;CB1;PU4,4;PD4,5,4,7;PU120,15;PD122,18,125,12,150,33;PU3142,0;!PG;;
    I need to know what the following commands mean, including their fields:
    Code:
    MK4,4,0,0;
    CB1;
    !PG;
    And what is the significance of the double semicolon at the end?
    Thank you.
    Feb 2003
    25
    Found that with Google:
    https://www.innovaart.com/faq-items/...k-and-pk-mean/
    Hope it helps
    Richard
    Sep 2007
    5
    Re: Plotter file starts with "MK"
    Yes, this helped, thank you.
    So, MK4,4,0,0; specifies CMYK values. I am guessing the fields are in the 0-255 range.
    The !PG; command should stand for 'Page', which basically means the end of the job. Although I don't know what the deal is with the exclamation mark.
    So now, if only I could figure out what CB1; means.
  1. please help : output file from Enroute have "plt" extension and not "cnc"
    By isam ali in forum Uncategorised CAM Discussion
    Last Post: 06-29-2017, 03:15 PM
  2. Replies: 0
    Last Post: 06-28-2017, 12:21 PM
  3. Replies: 1
    Last Post: 09-28-2016, 04:18 AM
  4. Replies: 4
    Last Post: 05-15-2015, 06:00 PM
  5. Xaxis starts to "jump" during routing
    By Firestar in forum DIY CNC Router Table Machines
    Last Post: 11-23-2011, 04:05 PM
