Having an strange issue. Been using Desk CNC to run a 4 axis foam cutter, which DeskCnc has created a whole CAM system to extract G code with. This works well and makes good code, but for some reason, the created code will not obey feed speeds. No matter what I change it to, nor how drastic, it stays at one extremely slow speed. It feeds in and out at much faster and what I consider regular speeds, but as soon as it does actual cutting of an object, it slows to molassas. I use only one feed speed in the beginning of the code, so I'm not sure what's telling it to slow down. Has anyone else had a similar problem? Anyone know a way around this?
