586,060 active members*
4,165 visitors online*
IndustryArena Forum > CAM Software > Mastercam > lathe c axis new plane
    May 2017
    19
    I always get lost when doing this. I have a hub that I need to drill/tap and mill/bore a hole in. I'm having issues getting the bored hole at the x+ position so that I can mill it, lathe has live tooling and y axis movement. I draw a line from center to the hole and created a new plane there, have Z arrow out and X arrow toward the hole. part is only allowing a 3d contour, obviously have something wrong when choosing the plane. Anyone have an online tutorial to show me the correct way to do this?
    Mar 2017
    314
    Re: lathe c axis new plane
    just one hole?
    you dont need to make a new plane . on the mainspindle at least.
    heres one way to do it. On top view (alt+1)Draw a line down the center of rotation(x0.) draw another perpendicular at z0 .trim this one to the top of stock your hole will be starting at. offset a line from this to the center of your hole
    select back (alt+3) select 3d or set you z level to the hole linefor 2d. draw a circle for your bore and make a point for your drill ops. go back to top (alt+1) use cross contour and cross drill.Mastercam does the plane figuring for you.
    Mar 2017
    314
    Mar 2017
    314
    all you needed was the point and circle at the correct z position along the part as seen from the top view. The hole depths could all be handled from linking.And normal to the back plane for C zero.
  1. Feed Plane Overwriting Rapid Plane V26
    By Jbrown74 in forum BobCad-Cam
    Last Post: 02-21-2014, 02:17 AM
  2. Replies: 2
    Last Post: 01-03-2012, 05:39 AM
  3. How do I set the z axis plane
    By functionbikes in forum Mach Software (ArtSoft software)
    Last Post: 03-04-2009, 01:36 AM
  4. Z axis not clearing feed plane
    By Jblk9695 in forum Haas Mills
    Last Post: 05-02-2008, 04:15 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
