586,036 active members*
4,343 visitors online*
    Aug 2018
    Flow waterjet intensifier question
    Hey guys, fairly new to working with a waterjet i was trained on the job by the operator i replaced and it was sad to say the least... anyways my queation is our intensifier keeps burning up tje HP seals on the pump qe have over 5600 hours on the machine ive been looking up information but only have mixed info... Our IT guy who was sent to the school and certified has debunked these suggeations so i felt like looking for answers else where..
    Could the early seal wear be caused by the HP Plungers and seals going bad being over 5,000 hours?
    IT guy says they should last 20 years due to the low psi being transferred through the system at that point
    Jun 2010
    463
    Re: Flow waterjet intensifier question
    If you are burning up your seal at lets say 10-20 hours of operation, plus you have over 5600 hours of operation. If you haven't done a major rebuild, and when I say major it means a complete tear down of the intensifier and a complete oil and filter change.
    More then likely your plungers are scored and they are eating right through your seals.
    If you are in the States give me a call
    I service Flow, KMT and Hyperthern waterjet.
    Maurice Phelps
    MCP Services
    678-548-1483
    Aug 2011
    23
    Look for chips in your plungers like small flakes missing. That will cause you to go through seals really fast but at 5600 hours that is very rare. A chip in a plunger would be cause for a new plunger which is big bucks. I have little experience with flow but is the issue on the static or dynamic side?
  1. Ingrasoll Rand waterjet intensifier 55000 psi
    By wanda in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2016, 05:32 PM
  2. Replies: 0
    Last Post: 08-31-2009, 02:38 PM
  3. Replies: 0
    Last Post: 08-04-2009, 03:20 PM
  4. Flow Waterjet
    By Flow_ken in forum Waterjet General Topics
    Last Post: 01-15-2006, 09:38 PM
  5. Flow Waterjet
    Last Post: 10-31-2005, 04:56 AM
