586,070 active members*
3,531 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Which bits to use for PCB milling?
Page 3 of 10 12345
Results 41 to 60 of 186
  1. #41
    Jul 2012
    89
    Re: Which bits to use for PCB milling?
    Hi again,
    & thanks again for your feedbacks.
    @Craig: As it is I have been looking at drillman1 previously when you first mentioned this vendor as a good source of tools. And I would really like to buy from him.
    The issue, however, is that living in Denmark we pay a 25% tax on the goods cost AND shipping costs when we buy something outside of the EU market having a value of more than USD 12. AND we pay an additional USD 25 handling fee for having the state handling these taxes. I don't mind paying the taxes but I do have a quibble paying USD 25 for tax handling every time I buy something that price-wise is in the "vicinity" of USD12.
    Thus I prefer finding EU market vendors for items that have costs in the USD 12 - USD 150 region so as to not pay the handling fee for lower value things. Not to mention that shipping time from the US or Asia to Denmark is long - and adding to this the tax department's handling time which is also a couple of days. All in all the most feasible place to buy tool parts would be either Denmark or Germany.
    When you originally suggested Kyocera-Tycom I did a search on the internet for a vendor within the EU but I didn't find any. It appears that most of the KT sales are in the US - if the search results can be taken as a guide for this.
    >> High speed spindle with controller unit << ... This could be interesting but I have to narrow my focus also money-wise as my main area is audio electronics - which in itself can be quite a costly affair. So in a first round I hope to make the machine I have bought work just quite fair for prototypes and small production ... or use it to make another CNC mill/router. Will have to ponder this over the next weeks.
    I have also been thinking about your TO-247 PCB milling: Unless you use very high voltages in your system I don't see why you need to consider arcing from a practical point of view ... There may of course be something that I do not know about (and there undoubtedly is!) but arcing typically is an issue at high voltages and high humidity. Just wondering
    @Roger & Craig: I have been thinking about the lubricant or fluid cooling and I would much prefer to not use any oils or the like. As it is I am sort of a "start-up" and I work from my home ... Thus using oils may spray out on the walls - or elsewhere - something I'd like to avoid. I found this video yesterday on youtube showing how to mill in steel with a router resembling mine: The person here has enclosed the water on the steel surface with something white (silicone?) - a process that would be feasible for me.
    https://www.youtube.com/watch?v=d-1BEqHR0gw
    @Craig: Do you think this would be beneficial for normal copper/aluminum work with bigger sized end mills (3 - 4mms) like e.g. face milling?
    And now, completing this post, I'd like to say again that I really do appreciate the feedback you have given ;-)
    Cheers,
    Jesper
  2. #42
    Jun 2010
    4256
    Your taxation system is simply obscene.
    Cheers
    Roger
  3. #43
    Jul 2012
    89
    >> Your taxation system is simply obscene. Cheers Roger <<
    Well, no doubt there are many views on this ... Overall I find it to have many positive aspects as well (Denmark is considered the country in the world where people are happiest) but in this case charging USD 25 to potentially handle taxes on goods worth USD 12 is less "feasible" to me.
    And then just a P.S. to Craig: I have already downloaded G-wizard which I am trying to acquaint myself with.
    Have a good day,
    Jesper
  4. #44
    Apr 2013
    1899
    Quote Originally Posted by evalon View Post
    Also - just out of curiosity - and if it's interesting to you! - do one of you have a link to a small CNC mill that will at least do aluminum perfectly
    Jesper
    Hej Jesper,
    "Perfectly" is difficult to define...
    I have a small CNC and it does mill aluminium with very satisfying results, better than what I expected when I built it. Mine is a moving table type, so the gantry is fixed, which increases the rigidity and that is good for a CNC. I have a hobby room inside my house, in the living area, so I don't use any chemicals or cooling. My spindle is a 1.5kW air cooled one with ER11 collet. Normally I am using 4 flute 4 and 6mm cutters which I am buying from Jula. I am very happy with those, and those are actually pretty cheap as well. There are different schools for milling aluminium, some claim that 2 flute is the way to go, but for me 4-flute works best. I think the secret is to find your optimal speeds, which depends not only on feed and speed calculations, but also on your machine. No point pushing the cutters too hard because that will only cause problems, on the other hand, if you feed too slow it will result in rubbing and far too much heat and melting/welding.
    Here is a short video where I am milling aluminium:
    https://youtu.be/LFFyb2XtpkE
    I have never tried steel and probably never will.
  5. #45
    Nov 2013
    4373
    Hi Jesper,
    if you want to mill heavy copper PCBs then you will need small diameter endmills. I have found no European supplier that can even get close to
    to drillman1 and I assure you I have looked and looked repeatedly, you can get small endmills in the EU but very expensive, even more expensive
    than your tax burden.
    If you buy $100-$200 at a time and the $25 fee doesn't look so bad.
    If you want to try steel get a 3mm endmill, spin in at 6000rpm and have a go. You will need coolant or it will smoke up in 30 seconds. Routers such
    as your Kress have very low torque, especially at low revs and then they are inclined to stall and thereafter unless you are quick on the Estop you will
    snap the tool. This is exactly what happened to me. I did get some results but it cost quite a few tools to do it. That's why I spent $2000 making a new
    spindle, you don't think I would do that unless I had to?
    By all means try machining steel, it may work OK, then again it may not, you may encounter the same problems I had.
    If you read Rogers description of MQL then you will see that he used kerosene and olive oil and in such small amounts that it doesn't pollute your work space.
    You can cut dry, try it, it may work OK for you. I've found that flood cooling improves the cut quality and tool life that much that I can't do without it irrespective
    of the extra complication.
    Try HSMAdvisor.
    Craig
  6. #46
    Nov 2013
    4373
    Wrong! I work with inverter welders day and day out. Typically DC Link voltages from 320VDC to 400VDC for PFC boost single phase machines
    ant 585VDC and up to 800VDC for PFC boost three phase machines. If you are not concerned about flashover think again, it happens.
    My servo drive will have, to start with, a 320VDC DC link but when I start trying to get its maximum output, 2.65kW, I'll need to go to a PFC boost
    arrangement of 400VDC otherwise I will blow supply fuses all the while.
    Craig.
  7. #47
    Jul 2012
    89
    Hi both .. Just a brief reply as the evening is closing in ...
    @A_Camera: Thanks for posting & linking to your video. IMHO it looks quite good the aluminum you have milled. I also took a look at your youtube video list and noticed the difference between your Z-axis spindle assembly #1 and #2. And I guess that a major part of my issues are related to a Z-axis spindle that is neither sufficiently rigid nor has the weight in the right places (and maybe the router motor). Regarding your link to Jula I couldn't sign up as it appears that one has to be from Sweden - right? When signing up there is no option for other countries ...
    @Craig: ...
    The thing is that as far as I can see drillman1 doesn't have endmills going down to 0.2 or 0.25 mms. And for now I think I also have to consider what I apparently need to be able to reliably - i.e. not an excess of wasted tools - mill PCBs at the sizes that are relevant to me. Reading your posts it looks as if it could be a quite expensive and time-consuming affair. So time to ponder ...
    Ok, fine. As I wrote in my post there may of course be something that I do not know about in this field - my main reason for posting the above was that I was thinking that if you didn't know then maybe I could contribute a bit here. But apparently not.
    I will see if I can find a link to Roger's MQL method ... And also take another look at HSMAdvisor.
    But I must admit that I look forward to a bit of weekend. It has been a week with many new inputs so my mind looks forward to some rest
    Best wishes from over here,
    Jesper
  8. #48
    Jun 2010
    4256
    If you want really narrow gaps between traces it is customary to use a V-bit cutter rather than a 0.25 mm cutter.
    How well they would work with the really thick copper layer you are talking about is another Q, but you can get small-angle V-bit cutters.
    A web site to really take a long look at is Precise Bits at https://precisebits.com/ These people really do have the goods for this sort of thing - but not cheap.
    Those import taxes are incredible. Do they charge similar amounts on gifts sent to you?
    Cheers
    Roger
  9. #49
    Nov 2013
    4373
    Harvey Tools have endmills down to that size but they are expensive.
    Rogers Precise Bits link shows 0.2mm endmills for $27US each and 0.25mm for $21US each. You are going to break those tools like they are
    going out of fashion so be prepared to spend lots of money.
    I got 30 0.5mm Kyocera Tycom two flute endmills for $80US and am still using them. I know where I'm going to spend my money!
    Craig
  10. #50
    Nov 2013
    4373
    we have a broadly similar tax regime in New Zealand.
    All goods coming into New Zealand are subject to G(oods) and S(ervices) T(ax) of 15% There are a few specific items which also have a sales tax, but vey few and no more than an
    additional 10%. New Zealand Customs don't bother to collect duty/tax of less than $50. Thus if your overseas purchase including shipping is less than $333NZD then no tax is collected
    and they let the item in.
    If its more than $333NZD then you have to pay. In addition to the tax they tack on an extra $25 for the paperwork and another $12.50 for an inspection (border security) fee.
    Like Jesper I don't mind paying the taxes but don't much like the additional fees. At least the fees kick in at a much higher level.
    The Government is quite keen to see all imports get taxed in which case we could end up like Denmark where a $20US item may suddenly become $50US because of fees.
    Interestingly the New Zealand Customs Department are reluctant to do it. They claim that all the small importations would cause a major increase in their workload and cost
    and yet deliver little more revenue to the Government. They have been talking about it for some while without a clear result. If they could do something that could rake in
    more tax then any Government would have done it already. The fact that they haven't suggests that a more reasonable attitude is likely. There would be a political backlash
    if they introduced GST on everything AND the fees and yet without the fees to defray all the extra work it would cost Customs overall.
    Craig
  11. #51
    Nov 2013
    4373
  12. #52
    Jun 2010
    4256
    Better note that the target market for Precise Bits was originally people doing marquetry inlays in hard wood. The idea of trying to use a 0.2 mm end mill on steel makes me shake.
    Cheers
    Roger
  13. #53
    Nov 2013
    4373
    Hi Roger,
    I have some 0.2mm PCB drills and they are so tender I cant really use them, there is about a 50/50 chance of getting them into the machine
    without breakage let alone drilling anything with them.
    0.2mm endmills in any substance let alone steel is going to end in disaster. I think Jesper's requirement of 0.2mm to 0.25mm between traces in heavy copper is unrealistic
    but you can't tell until you have tried it.
    Craig
  14. #54
    Jun 2010
    4256
    Hi Craig
    Yeah, just handling them can be 'interesting'. Dropping one is usually unfortunate.
    Mind you, I don't think trying to use such end mills on steel will end in 'disaster' - just a few broken cutters is all. Well - all cutters broken maybe. It's just $$.
    I have used (Chinese!) carbide V-cutters with a 10 degree taper (really pointy) on copper to get such narrow gaps. Standard weight clad laminate, so the copper is only ?35um? thick. Given the cross-section of the carbide at the tip, I was really reduced to making 20 micron steps on the Z axis. I did not break too many tips, but it was SLOW. And you do need a desperately low TIR as well, and a dead flat vacuum table.
    Cheers
    Roger
  15. #55
    Nov 2013
    4373
    Hi Roger,
    to call trying to cut steel with 0.2mm a 'disaster' is of course mistaken. The worst that will happen is breakage of tools.
    The cheapest I have found a known brand (Kyocera Tycom) is $3.80US each, plus shipping and import taxes.
    My experience with small diameter endmills started when I bought some 0.4mm (1/64 inch) tools from drillman1 for about $4.50US each.
    Over a period of a few weeks I broke all 10, with encouraging results but no real success stories. I bought another 10 and by now had the three
    major innovations/techniques in hand and results were much improved.
    Once I had used those I bought the 0.5mm endmills because they were on special. I realized once I got them that despite being only 25% greater in diameter
    over the previous 0.4mm tools they are much tougher. The cross sectional area makes them stronger. 0.2mm endmills I suspect will be very weak, not just the
    reduction of cross sectional area but the area consumed by the two flutes will inevitably consume area which would otherwise form the core and therefore the strength
    of the tool.
    I would recommend that Jesper start with tools somewhat larger, maybe 1/32 inch or 0.8mm. They are cheaper and more readily available. Thus he will be able to experiment
    with cheaper tools those techniques he will have to perfect before he starts on the real challenge of 0.2mm tools and the increased money and much increased sensitivity
    to failure/breakage.
    Craig
  16. #56
    Jun 2010
    4256
    very weak, not just the reduction of cross sectional area but the area consumed by the two flutes will inevitably consume area which would otherwise form the core and therefore the strength of the tool.
    Totally agree with this argument.
    Ideally one would reduce the size of the flutes, but then the flutes would choke on the swarf.
    Cheers
    Roger
  17. #57
    Jul 2012
    89
    Hi Craig & Roger,
    I can see that you continued the thread after I left for my weekend Friday ...
    I have thought about things over the weekend and I honestly don't think that my current CNC will be capable of milling PCBs the way I would like to. 0.5 mm deep tracks with 0.2mm spacing between tracks - from what you have written - hardly will work in practice. And I have now succedeed in etching 140 um copper PCB with the 0.2mm spacing that I would like.
    So I have decided to let go of milling PCBs with my current CNC and instead try to find some PCB laminate with a 6 oz or 7 oz copper layer (0.2-0.3mm thickness base layer, single or double sided) and then refine my PCB etching process. Maybe I can make these 0.2 mm spacings with such a PCB. Some compromise but still acceptable and not least do-able within a reasonable time & cost frame. And when I need a thicker copper layer I will have to do with a larger track-to-track spacing - which also means that I can use e.g. 0.8 mm diameter end mills.
    In have also decided to buy a HQ & costly end mill (3.5 mm) from a Danish tool manufacturer - just for having a good tool reference - delivered in a short time - so as to try out my CNC before deciding how to proceed. This should tell me whether the rigidity is far off what is required - or I may get it to be as I need/wish with a sensible amount of improvements. When I know more about this I may buy from Drillman1 (which I consider a very good reference) & otherwise decide what to do with the CNC machine.
    @Craig: Any chance I can ask you to link me to a couple of end mills (face milling & ball nose) from Drillman's selection that is especially suitable for copper, brass, bronze & aluminum milling? This way I can see what is the optimum material for this and subsequently choose sizes etc ...
    Regarding cooling I have read a bit into the MQL concept, however, I still would like to keep things as simple as possible so still considering here.
    Thanks again for your considering & replying here - I realize I have met with some very qualified people here
    Cheers,
    Jesper
  18. #58
    Nov 2013
    4373
    Hi Jesper,
    I'm going to assume you are using a router as a spindle.
    What collets do you have?. If its a European router then it will most likely have a 6mm collet. It may have a 1/4 as well. Having the right collet is essential.
    drillman1 is in the US and most of the tools he sells are US made. If you wish to take advantage of the prices he offers for tools then having 1/8 and 1/4 collets
    for your router is going to be important.
    Second issue is what speed control you have over your spindle. The universal motors used in routers tend to be fairly low torque and high speed.
    You can reduce speed but the torque does not improve, with a universal motor torque is proportional to current. Up the current at your peril.
    Also the fan built in to the armature will spin that much slower and at slow to middle speeds the router may overheat. Keep a real close eye on it
    until you are familiar with its cooling properties at slower speeds.
    Just about any endmill will work OK for materials you've mentioned. The real drama starts when you start talking steels, stainless steels, titanium and super alloys like discalloy.
    Do yourself a favour....to start with don't bother trying to mill steel, you'll smoke up and break tools and wonder what the hell is going on!
    Brass is fun to cut, it cuts well and is not inclined to form BUE. Sticky aluminum like 1000, 3000 series and to a slightly lesser extent 5000 series and pure annealed copper
    are more troublesome and BUE is likely. You may get away without cooling/lubrication but then again you may not. BUE is no respecter of whether you want to keep it
    simple or not!
    Bronzes can be fun. Silicon bronze has hard bits in it and blunt tools pretty dams quick. Phosphor bronze is used for making springs and can be quite hard but suitably
    annealed machines like a dream. Nickel bronze is tough and molybdenum bronze is tougher again.
    The bottom line is that you have to get some tools and some materials and try it out. There are certain rules of thumb and they will make sense to you once you've
    done some milling. It might be worthwhile to get some HSS tools, they are cheaper than carbide and tough as old boots, if you don't overheat them!
    Tell me what collets you have or can get and what speed control you have and maybe we can find some cheap tools to experiment with.
    Craig
  19. #59
    Jun 2010
    4256
    Hi Jesper
    Etching thick copper: agree.
    Craig's comments: +1
    Look for end mills which are specified for aluminium. They will be good for plastics as well. Never try to use them on steel etc though. 'Honed' cutters are very good but dearer.
    Suppliers: I have had good stuff from CarbideChiu on eBay as well.
    Cheers
    Roger
  20. #60
    Dec 2017
    7
    I have been etching my own PCBs for some time and I use single flute ("D") cutters in a 1/8" collet. Carbide or tool steel will work fine for etching copper. I use solid carbide, but tool steel isn't as brittle. Single flute cutters, possibly referred to as V-bits, come in several long tapers to various tip widths. I've never broken one but I generally use .3-.4mm tip for more separation. The shape of the "D" cutter makes it quite strong (because of the taper). I pilot all hole locations with the "D" cutter and later drill them to .03" ( generally the size of most discrete electronic component pins - ICs, transistors, pots etc.)
    Skip
    PS: I use carpet tape to hold my stock in place and flat.
Page 3 of 10 12345
  1. Milling bits
    By genesiospinola in forum Community Club House
    Last Post: 08-01-2013, 12:47 PM
  2. CNC Milling Bits
    By continentaldia in forum News Announcements
    Last Post: 07-09-2012, 07:25 AM
  3. milling bits
    By pauley in forum Want To Buy...Need help!
    Last Post: 07-05-2012, 01:46 PM
  4. PCB Milling bits
    By reiyuki in forum PCB milling
    Last Post: 09-14-2008, 06:31 PM
  5. milling bits
    By pike88 in forum WoodWorking Topics
    Last Post: 09-24-2007, 06:02 PM
