586,347 active members*
3,458 visitors online*
Results 1 to 3 of 3
    Aug 2018
    Biesse Rover 20 error ECN-26
    hi everyone
    I'm starting little wood workshop and bought myself old Bisse Rover 20 with NC500.
    Before shipment seller made me test with machine. Showed everything worked. Now machine is in my workshop and I can't get electrospindel (main spindele) to work. It takes the tool out of magazine, but then I get the error „ECN_26 – Bit thickness < working depth (cen) (tp) – The program being carried out on the centre (cen) wants to use TP (tp) in a process having depth greater than the thickness of the bit fitted. Check the program and retry.“
    I have tried change different parameters for router tools and tried old programs (form previeus owner/s) but result allvays the same. When machine should start the electro spindle to rotate I get the error ECN-26. (Drilling head works fine)
    Local Biesse service checked my software and they sayd it looks ok. I don´t know how deep the looked. I tried to write direct to Biesse, but no response.
    I there onyone who can give me some advice. Any opinion are highly appreciated.
    Is it possible that from machine transport moved something and it couses that error?
    Is there something else what can couse this error?
    Best regards,
    Siim
    Feb 2018
    59
    Re: Biesse Rover 20 error ECN-26
    did the machine start up with any plc errors?,,,if everything is good with electrica?,,,is there a tool in the spindle?,,,,inside the datimac check to see if a tool is loaded?,,,,did you remove all of the orange shipping brackets?,,
    -The Infamous Chev
    keysoftwareservice.com
    Apr 2019
    13
    It looks like the machine is being told to cut deeper than the programmed useful length of the tool. What is the tool length in the tooling data?
    Quote Originally Posted by Rover20c View Post
    hi everyone
    Best regards,
    Siim
