Originally Posted by
dharmic
Not my design but I've found it useful. The gantry on my machine has about a 140mm clearance and the Z travel is about the same (smallish machine). The spindle is clamped to the Z table with a couple of rings which can be loosened off. So I can work nose-to-table as jones describes, or for taller work I can push the spindle up through the clamps and work on top of material that will clear the gantry, with room for tooling.
A longer Z axis would save having to move it around but, of course, that means more torque around the X axis and consequently a greater deflection under load or a need for heavier gantry etc.
