586,069 active members*
3,402 visitors online*
IndustryArena Forum > CAM Software > UG NX > Divides the NC program
    Hello.
    We have an CNC machine whose memory is limited to 90 kb.
    How do we change the postprocessor in postbuilder, so that it automatically divides the NC program into 90 kb?
    Mar 2016
    Re: Divides the NC program
    Hi
    There is special Custom Command "pb_cmd_tape_break.tcl". All you need to do is to import it.
    Quote Originally Posted by ncmatic View Post
    Hi
    Hello. Thanks for the answer.
    I knew about this function, but I could not get it to work.
    Perhaps you have an example of a postprocessor using this function, or a detailed description of how to use it?
    Sep 2009
    78
    Another method you can use to split operations is Divide. However, it can only divide an operation by time or distance, not by size.
    NX 10.0.3
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Replies: 1
    Last Post: 02-11-2015, 02:38 AM
  3. Replies: 1
    Last Post: 09-18-2014, 12:29 PM
  4. Replies: 4
    Last Post: 03-06-2013, 07:56 PM
  5. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
