586,042 active members*
3,756 visitors online*
IndustryArena Forum > Community Club House > Education - Teachers and Students Hangout > DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems
Results 1 to 1 of 1
    Aug 2018
    Exclamation DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems
    Hello,
    I have a DYNA MYTE 4800 with MITSUBISHI MELDAS 500 control. I'm not sure, but I think that the model is old and discontinued. Well, I've two problems with this CNC:
    1./ SPINDLE
    In MDI mode I turn on the spindle and works ok, but when a change to HANDLE mode the spindle turns off right away. I not sure if that is a coding problem or wire connecting PCB problem (electronic issue).
    2./ ATC-MAGAZINE
    In MDI mode I enter the tool code for automatic change, for example, T10 M6, but the panel shows me this failure code:
    'P290 IF SNT. ERROR'
    MDI EDIT
    Attached Thumbnails Attached Thumbnails ATC_Magazine.jpg   Mitsubishi_control.jpg   Meldas500_screenpanel.jpg
