586,105 active members*
3,221 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Weihong NK260 vs NC Studio, which one is better?
    Sep 2018
    Hi all!
    I am new to this forum and machining as well. I am purchasing a new milling machine from china whose specifications are :
    Description Parameter
    X Y Z working area 600*600*200mm
    Table surface T-slot Work table
    Frame Cast steel
    Z structure Ball screw
    Max. Rapid Travel Rate 6000mm/min
    Max. Working Speed 4000mm/min
    Spindle Power Motor 2.2 kw spindle
    Engraving Speed 0-4000mm/min
    Spindle Speed 0-24000RPM
    Drive Motors Imported Japan Yaskawa Servo Motor and Driver
    Working Voltage AC220V/50/60Hz
    Operating System WEIHONG NK 260 Constrol System
    Interface USB
    Flash Memory 128M( U Disk)
    X,Y Resolution <0.01mm
    Software Compatibility Type3 software, Ucancam software (Option: Artcam sofa
    Net Weight 600KG
    Gross Weight 700KG
    2.2 KW Spindle
    Please help me choose the controller! I will be very grateful to you
    Mar 2020
    27
    Re: Weihong NK260 vs NC Studio, which one is better?
    Hi, I am from WEIHONG, NK260 is better.
