586,094 active members*
3,949 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Threading/OSP 5020L
Results 1 to 9 of 9
    May 2015
    35
    Threading/OSP 5020L
    I am threading in the IGF mode. I need to enter 11-1/2 TPI and I cannot figure it out. I can only program with IGF. I am not good with entering G code. It is a 2" NPS thread. How do I get a half number entered?
    Jun 2015
    4154
    Re: Threading/OSP 5020L
    hi jmooresshop i played with a newer version of igf, in metric ( milimiters )
    it is possible to switch between tpi and pitch size, and in pitch is possible to input a number that is not an integer
    i don't have experience with your machine, but i would input in igf 11 tpi, and after that i would edit the code and replace 11 with 11.5
    if it would work, it means that the G code can handle a number that is not an integer, but igf uses a filter for integer
    if it would not work, then i would change the arguments of the G code ... i will experiment with this tomorrow, on the machine / kindly
    May 2015
    35
    I tried to modify the g code but it doesn't like my changes. I uploaded the g code as it is before editing.
    Quote Originally Posted by deadlykitten View Post
    Dec 2008
    3109
    not sure if IGF would accept it
    .. but try 23/2
    May 2015
    35
    I changed the 11 to 11.5 and removed the M7 and 3. It worked fine after that.
    Quote Originally Posted by Jmooresshop View Post
    Jun 2015
    4154
    hi, that "M7 and 3" is an M73 ( Infeed pattern ) which is used together with M33 ( Zigzag infeed ) to generate something pretty similar to attached image
    it seems that on your control is not possible to use J=value<>integer + M73 and M33
    however, if you wish to achieve that movement, i can code it for you
    this is another reason why i love custom infeed paterns and stuff : actually is all fine, until you hit a case when you realize that you are not in full control; i stopped using G71 a while ago, and all my threading codes are using G33 + whatever pattern
    for me is much easier and faster to code a thread in G33 than test your code or write this post kindly
    Apr 2009
    1262
    Superman is spot on. F2 J23 is your solution. No decimals are allowed in the J command, but F can definitely be 2.
    Best regards,
    Jun 2015
    4154
    hello mr wizard yup, i am also pretty sure that he was saying exactly the same thing ...
    seems that J11.5 worked only after removing M73 ... hmm, a bit strange, and i guess i will test it soon
    i just read again attached paragraph from G71, and at 1st glance, it seems that J should be an integer, but this is more an interpretation, because it is not clearly specified
    hey jmooresshop, try also to replace M22 with M23 ( check attached ) :
    ... if there is no thread relief, this will smooth out the disengagement of the tool from the material
    ... also this should help reduce the shock associated with turret going among X near the thread end; however, if parameters and code are not corelated, there may be some disadvantages like downtime; i can develop this if you wish / kindly
    Jun 2015
    4154
    on my lathe, this code delivered a pitch=0.5, even if F & J arguments are real numbers or formulas
    however, i am concerned about the depth of cuts, because i specified D=0.300doc and U=0.100finish, and this was the output ( pls check attached ):
    0.300 ... 0.300 0.200 0.200 0.172 0.053 0.037 0.038 0.100
    blue numbers represent those transition passes between D and U, that are calculated by the controller accordingly to the infeed patterns
    generally is all fine, until chatter appears sporadic ( on some intermediary passes, or on non-consecutive parts ) and/or last transition passes have a lower doc then the finish pass, etc
    i am not saying that cycles are bad, but sometimes a particular case will require a different approach, and that approach should deliver full control over the passes & infeed, otherwise trials time may increase drastically / kindly
    Code:
        G50 S2000 M867
        G00 Z250
        T+5*101 M66 G97 S1000 M03 M42 G00 X55 Z5 M63
        G71 X45 Z-25 D0.3 U+2*0.05 H5 F4.678 J4.678*2 M33 M73
        G00 Z250 M05 M63
        M02
  1. LB 15II osp 5020L
    By MCR-B II in forum Okuma
    Last Post: 10-19-2012, 05:19 PM
  2. Okuma OSP 5020L
    By BrianM03 in forum Okuma
    Last Post: 04-10-2012, 04:13 PM
  3. osp 5020L monitor went out!!
    By guydrisc in forum Okuma
    Last Post: 08-25-2011, 09:49 PM
  4. 5020L Not booting
    By JasonMiller in forum Okuma
    Last Post: 05-13-2010, 06:11 AM
  5. OSP 5020L
    By MKATool in forum Okuma
    Last Post: 04-06-2008, 08:08 PM
