586,555 active members*
3,473 visitors online*
    Fanac Alarm No.s
    Hi dears
    I have a doosan xnc machine with ot fanuc control
    And I have two alarms on the screen with 310 and 320 numbers
    That appeared after the battery alarm
    Do you know everyone how the solution it?
    May 2016
    526
    Re: Fanuc 0M-A need parameter
    I thought Doosan put the procedure in the manual
    Dec 2009
    960
    Re: Fanac Alarm No.s
    310 ALARM-----APC alarm====absolute pulse coder alarm=====X axis need zero return
    320 ALARM-----APC alarm====absolute pulse coder alarm=====Z axis need zero return
    you lost the origion of motors so you need to make it back and for that you must move the machine in the place where was the old origin,both axis==machine origin===,make PWE=1 ,ignore the alarm and go to paramater 22 and the first 2 bits from rigt must be 1.
    you must have now parmaater 22 like this:00000000 and must be 00000011.
    after change power off the machine and back again adn you must be done
    check also before this if paramater 21 look like :00000011 ,if not make it like this.
    good luck.
    this is the translation of this video if you do not understand what that guy is saying----
    https://www.youtube.com/watch?v=9QijS467W7Q
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Replies: 1
    Last Post: 04-10-2017, 05:01 AM
  3. Victor C16 with Fanac 3t controller
    By Ozcad in forum Fanuc
    Last Post: 10-05-2014, 09:20 PM
  4. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
