586,905 active members*
2,740 visitors online*
    Bridgeport VMC600/22 buffer batteries
    VMC600 is displaying a 'exchange buffer batteries' warning - for about 4 days.
    I understand these batteries are located in the 'gold' box by the main electrical supply panel.
    Am I right in thinking I have to momentarily cut the power in order to enter the panel then turn power back on before changing the batteries?
    Sep 2009
    135
    Re: Bridgeport VMC600/22 buffer batteries
    Did you resolve your battery issue?
    What controller is on this machine?
    1121
    I am late, but for future reference
    Assuming a Heidenhain control
    usually when the message first comes up, the batteries are low not dead.
    yes you need to shut the power off due to the interlocked door, otherwise you change the batteries with the power on.
    If you do not have your parameters backed up, do it now!
    So, open the door
    turn the power on by fooling the little lever on the power switch
    replace the batteries with the power on and you will not lose your programs and parameters
  1. Bridgeport VMC600 Gross positioning errors please help (done searches)
    By centoproject in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2018, 07:43 PM
  2. Bridgeport interact buffer batteries
    By jack-pat in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2015, 04:01 PM
  3. Bridgeport VMC600 30 Digital 2001 Operating and Maintenance Manuals Needed
    By andy200470 in forum Bridgeport / Hardinge Mills
    Last Post: 03-19-2013, 11:58 PM
  4. Bridgeport Interact 421 Milling Center - Where are the batteries??
    By CNC-Joe in forum Bridgeport / Hardinge Mills
    Last Post: 04-16-2012, 03:35 AM
  5. Bridgeport VMC600/22
    By de_firma in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2011, 11:50 AM
