586,060 active members*
3,523 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Will this spindle motor be a good choice?
Results 1 to 12 of 12
    May 2006
    309
    Will this motor be a good choice for a Taig mill or are there more affordable alternatives with the same range of rpm?
    Jul 2007
    1602
    Re: Will this spindle motor be a good choice?
    If you want a project, this looks like the motor he is using:
    https://www.ebay.com/itm/Consew-CSM1...AAAOSwcLxYJlCZ
    It is a good match to the Taig. I suggest you join the Yahoo TaigTools group if you haven't already. There are several discussions regarding using these motors on a Taig as well as a few folders in the Files section with all you need to know to roll your own.
    bob
    May 2006
    309
    Yes it looks that it must have the same rpm after gearing up the speed by using a smaller second wheel. But where can I get these wheels and a belt that fits for this project?
    Nov 2005
    222
    This place should have what you need. I have used them a few times. They have a center-distance tool that will help you pick the belt length for the pulleys you chose to get the distance between centers you desire.
    Small Mechanical Components: Precision Gears, Timing Belts, Gear Assemblies, Timing Belt Pulleys, Couplings, Bearings and much more - SDP/SI
    John
    Aug 2016
    37
    FYI, amazon has the cheapest price on the Consew CSM1100. Lot of information about them on the Taig Facebook group too.
    Aug 2016
    37
    FYI, you want to be convinced at what a Consew can do? Check out my Youtube channel
    https://www.youtube.com/channel/UCFC..._as=subscriber
    May 2006
    309
    Quote Originally Posted by rcheli View Post
    John
    I tried that calculator but I didn´t understan why I should set values for ratio and number of grooves. Shouldn´t it be enough to set 40 in pulley A, 20 in pulley B and center distance, and let the tool calculate the rest?
    Nov 2005
    222
    I did find their tool al little confusing at first. You can specify the ratio and center distance an it will pick the pullies and belt or you can specify the pullies and belt and it will tell you the center distance.
    Aug 2016
    37
    Quote Originally Posted by jaru-eri View Post
    I posted another manufacturer and calculator on your other thread and gave you all the info to put in to find exactly what you are looking for. These are tried and true numbers many of us on the Taig Facebook group are already using. We also already have the CAD files for the motor mount to make it more sleek, better adjustment and even cutout for the pulley hub so you can push it closer to the motor. Check out the file section in the Taig Facebook group for that.
    Dec 2005
    436
    jaru-eri: did you use this motor, what is your opinion of it?
    Sep 2014
    10
    Yes ,this will spindle motor be a good choice.
    May 2006
    309
    I´ve just got the motor, but I´m going to wait for other parts before I can set it up, so I haven´t tried it yet.
  1. Good motor choice for CNC router?
    By moparx12 in forum Stepper Motors / Drives
    Last Post: 07-20-2016, 01:26 AM
  2. Spindle of Fanuc Motor is not working good
    By braided in forum Australia, New Zealand Club House
    Last Post: 11-01-2014, 06:39 AM
  3. Sherline spindle a good choice?
    By pwg1824 in forum Benchtop Machines
    Last Post: 05-09-2012, 10:45 PM
  4. What machine is a good choice for me?
    By n8o in forum Benchtop Machines
    Last Post: 11-30-2009, 04:41 AM
  5. Good Rack Choice?
    By DeviousMW in forum Waterjet General Topics
    Last Post: 03-23-2007, 04:12 PM
