586,115 active members*
3,422 visitors online*
    Jan 2017
    What's the best option?
    Hello!
    I've been building a diy cnc and want to replace my old kit i got years ago.
    Dunno if it matters but it 1,5 * 1 meter
    I have
    3x HN200 3451 0640 AXR08 and
    3x 85BYGH450C-012B
    What stepper motors would u recommend me to use?
    It will be connected directly to RM 2005 ballscrews.
    The stepper drivers I have are
    dq860ma.
    and powering them are 3x 60v 5.8amp power supply
    Sorry for the dumb questions, i'm new to this and don't really know what to look for in the datasheets.
    /Patrik
    Dec 2012
    199
    Re: What's the best option?
    Your drivers will be fine for both the stepper motors, they can handle up to 7.8A and the 60V power supply is fine as well
    the first motor is 3A 22mH and a holding torque 9.3 NM
    The second one 6.4A 2.5mH 6.2 or 7.6NM
    the A is not important as long as the driver is able to provide it. Your driver can do
    The mH is more important as this is directly related to the max RPM. The lower mH the higher the RPM so the second motor will run about 9 x faster max speed with the same input voltage on the driver.
    If you need hgh speed, use the second motor.
    The NM is related to the power the motor can give. Both are strong motors which I expect will run this cnc without problems.
    good luck, Toin.
    Jan 2017
    Thank u for the answere!
    I want more speed, so I go for the low mH motors.
    and thanks for the info, that's really good to know!
    /Patrik
  1. OPTION EIA/ISO
    By VECKT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-03-2018, 10:01 AM
  2. Replies: 0
    Last Post: 06-09-2016, 03:25 PM
