586,075 active members*
3,989 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Novusun NVUM controller + Spindle help
Results 1 to 6 of 6
    Setup:
    Windows xp
    mach3
    Novusun NVUM v2 controller
    Knock off askpower VFD (i think)
    This is my 1st major cnc build, and i am at the final hurdle - controlling the spindle via mach3 and a vfd. The novusun control board (which has caused endless confusion) is a usb parallel port emulator. Where I am currently, is the vfd reads frequency when the Spindle cw control is pressed on mach3, however, the spindle won't come to life regardless of which pin outs i put it on. The spindle works fine with the VFD in manual mode which rules out some problems, I am just very confused about the relationship between mach3 and the novusun NVUM and how this controls the spindle. Anyone got any experience with this kind of setup?
    Jun 2011
    692
    Re: Novusun NVUM controller + Spindle help
    There's typically an enable line, a speed (analog, 0-10V and/or 4-20 mA,) and a CW/CCW line.
    Does the NVUM have an analog out for the spindle?
    Nov 2011
    13
    Quote Originally Posted by charlierj View Post
    Setup:
    Windows xp
    mach3
    hi, may ask what setting did you use to send signal to the vfd. i have a similar controller different vfd but the pin and port number should be the same. thank you.
    Feb 2014
    5
    Setup:
    Windows xp
    mach3
    Hi Charlie I have the same setup as you but I haven't been able to even get the right driver loaded for anything to move. In the NVUM manual it says to load "NVUM-Novusun-Plugin-Ver-2.0A" upon opening Mach 3, well I can't find that exact driver and Bulkman are not quick in replying. Help!!!!!!!! Rick
    15362
    Setup:
    Windows xp
    mach3
    So I looked up your NVUM and it has a 0-10v analog output so that will be fine for you speed control, I don't see a Rely so you will have to get one solidstate that can switch the NVUM output voltage
    ON / Off depending on the VFD Drive you have you most likely needs a relay that is turned ON / Off by an output from you NVUM if you have a Rely in the NVUM you can use that the Connection on the VFD is FOR and DCM
    M3S12000 should give you 5v output or 2.5v output from the PWM output of the NVUM
    Mactec54
    Jan 2020
    Quote Originally Posted by skrubol View Post
    How do you enable these? Thanks
  1. Help with Novusun NVUM V2 USB control card
    By Winterdragon in forum Controller Cards
    Last Post: 06-26-2022, 08:13 AM
  2. NVUM CNC Controller setting it up with the DQ860MA Micro stepper Driver
    By adamfromUK in forum CNC Machine Related Electronics
    Last Post: 08-03-2018, 06:37 PM
  3. NVUM controller , the usb controler ...
    By Andreiir in forum Stepper Motors / Drives
    Last Post: 12-30-2016, 09:48 AM
