Im ready to retire my '95 Acer Knee mill with centroid controls and step up to a real machine to keep up with production. I have my eye on a 2002 VF-2B, this will be the biggest purchase yet for my business so I want to make sure I get a good machine. Im just kinda looking for some advice and what to watch out for. To start, whats the "B" option add? The following are the specs of the machine:
X-Axis: 30.0"
Y-Axis: 16.0"
Z-Axis: 20.0"
Spindle Taper: CAT 40
Spindle Speed: 10,000 RPM
Spindle Drive Motor: 20 HP - Vector Drive
Tools: 20
Approximate Dimensions: 88" x 58" x 104"
Machine Weight: 8,000 LBS
Equipped With:
Haas Control
Rigid Tap
Programmable Coolant
High Speed Machining
Chip Auger
8 MB Memory
2 Speed Geared Head
Are there any options missing that are a must for most situations? I dont plan on doing any 4 axis machining so the prewired option is not neccessary for me. Anything bad about the 2002 year machines? I will be machining about 50% alum, 25% steel, and 25% SS. The machine is located in MN and I am in PA so seeing it in person is not an option. I will however pay to have a HAAS tech do a quick inspection on it. Any input or advice would be greatly appreciated!
Thanks for your time,
Jim
