586,103 active members*
3,859 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Getting ready to buy - First VMC
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2013
    24
    Ok so I'm getting ready to buy my first VMC. Looking for a Haas VF-2 ~95-00, preferably as new as possible. My budget is ~$18k for the machine only - will be gathering tools as I go.
    I've been offered a 99 VF-0E at~$20k incl. a 4th axis HRT210. Its got the Vector dual drive, 710IPM, brushless servos. Would I be making a mistake in choosing a VF-0E over a VF-2? Its belt driven, so I guess its not as powerful as the two speed gearbox' VF-2s at low rpm. In my research I find that VF-0Es incl. 4th axis are priced approximately the same as a similar year VF-2 without a 4th axis.
    Is the 4th axis really necessairy? Im under the impression that many shop environments never use them, they just having them laying around.
    Main purpose of the machine is prototyping and small series production as a hobby; Im a MSc. mechanical engineer. Main reason Im going straight to a Haas is I dont want to be stuck with a underpowered Tormach that I will outgrow after a year.
    Im going to be producing molds for sand casting, prototypes etc. Similar to this intake manifold project I did during my last years at uni:
    andreasriseng's Library | Photobucket
    Andreas
    Nov 2006
    490
    Re: Getting ready to buy - First VMC
    The 4th axis could be handy down the road if you get into it, but it's specific to certain applications. You could take advantage of it if you plan to make multi-sided workpieces, although it may over-complicate things for small quantities. The other big use is batches of multiple small parts since you can pack them into the machine all at once, but with some work you might be able to do that with a typical 3-axis setup as well.
    Having said that, the extra drive will probably increase the value a little bit. The HRT210 is an 8-inch rotary platter, so definitely not the smallest piece of hardware. Might be valuable to someone
    Speaking about the gearbox, it'll make a noticeable difference for any high-torque tool like a heavy facing cut or a large-diameter drill or tap. It'll make no practical difference for anything running above 2500-RPM, so finishing operations and smaller tools won't care. Generally I tell people it's more effective during the roughing cuts rather than the finishing cuts.
    I will say one thing, though, that is drawing a line in the sand for me in particular. Around this timeframe (1999) Haas was making the switch from brushed-to-brushless servomotors, so there are some machines that have INCORRECT "brushless 710-IPM" stickers on the front of the enclosure. They're actually brushed and rapid at like 400-IPM or something. The problem isn't the speed, but rather the older controller and motion hardware which is less reliable and no longer serviced. I have a machine where this was a major source of confusion when we bought a rotary axis specifically for it, only to realize it was incompatible...we ended up upgrading the entire machine to run the newer-style rotary ($$).
    So I would be cautious buying a mill from this era because it may actually have older hardware installed despite the [literal] sticker on the front saying otherwise. I don't know how prevalent it is, but I'd prefer a machine from like 2000 or newer, since the controller saw some upgrades around that time. But yeah I know that means passing up on a deal...
    I have two mills from around this era (97 and 99). They both still work decent for what they are, although I don't follow the used market enough to know what they're worth.
    Nov 2013
    24
    Thank you for your reply, Ydna. Is there a way to check if the machine really have the brushless servos?
    I'm not going to use this machine to compete with production shops, only do small production series of my own products, so I guess I'm not really in the need of a gearbox - I can just run a little slower I agree on the points you are making with the added capability of the 4th. I do see some real benefits of having it - maybe making a big trunnion for larger part and running multiple parts in one setup.
    If anything this machine is possibly a bit cheaper than the other machines I've seen lately, being the rotary driving the price up. Another pluss is that the machine is located not too far from where I live.
    One will always want a newer machine, but I believe a machine like this will fit my needs. Anything newer will just be more money Im a bit surprised about how well these machines hold their value; I can get a brand new base model VF-2 for about $42k that will last past my lifetime in my small, private shop.
    Nov 2013
    24
    I spoke too soon; just ordered a brand new VF-2.... :banana:
    Feb 2010
    1184
    Quote Originally Posted by ar_cnc View Post
    That escalated quickly!! Enjoy the new machine.
    Jun 2004
    6618
    Congratulations. That may have been a better decision. It is the one I made last year. After looking at the used machines and how well they hold their value, to get one near half price would have meant a 20 year old operating system. A new machine was simply a better investment. It comes with at least a one year warranty that can be extended, but not sure it is worth what they charge. You will only know that in hindsight.
    Lee
    Nov 2013
    24
    Yeah escalated pretty quickly although I've looking for a machine for years. The VF-2EU is on sale so got a nice deal on it. I agree LeeWay; looking at this as a long term investment I believe this will be the better option. I did not dare venture on with a 20 year old machine not really knowing the condition its in before getting it into the shop.
    Are you happy with yours, LeeWay?
    Just got the machine with the bare essentials though, 32Gb memory, WIFI and pre-configured for TSC. Couldn't afford any more extras. I can always add on in the future, the first thing being probably the swarf auger.
    Theres so much good information and knowledge available out there about these machines, videoes etc. on YouTube, that made my decision easy.
    Stay tuned for many noob threads and mistakes; 3 months until delivery :cheers:
    Andreas
    Oct 2010
    171
    IMO, you'll want to add WIPS (probing and tool setting system) and High Speed Machining. That'll cost an additional ~$10k Once you've used a probe, you'll never look back.
    If you're going to do any mold work or anything that is contoured surface requiring smaller-ish cutters, you'll definitely use High Speed Machining.
    JMHO
    PM
    Nov 2013
    24
    For the time being I don't have any customers, and I'm only jerking around on a hobby basis, I can live with setting tool heights etc. manually
    Jun 2004
    6618
    Andreas
    I absolutely love our Mini Mill. There is not a single aspect of it that was not an upgrade from our Novakon Pulsar. The Pulsar is a decent machine itself. The only extra I ordered was the rigid tapping. I am still convinced that was the right choice for us. I may one day upgrade to the WIPS, but for now, the Haimer does a good job.
    Lee
    Jan 2012
    97
    I'm pretty much in the same situation. I opted to order a new VF-2, it should be here next week. Having used Haas CNC's at various shops, and on a tight budget, I considered whether I should get either TSC or the Renishaw probe. I wish that I could've afforded both but that wasn't an option. In the past, when I had both available, I used the probe several times a day and TSC maybe once a week... So I picked the probing system. Kind of a bummer because I do love having TSC.
    I also opted to get side mounted TC and HS machining along with getting it pre-wired for 4th axis. I would like to add a HRT160 or 210 in the future...
    Nov 2013
    24
    Awesome machinster, you got a lot of options! Would you post some pictures of the install once its all up and running? :cheers:
    Jun 2004
    6618
    Yes, I always like seeing how others install machines.
    Lee
    Nov 2013
    24
    New vice-day!
    Machine will be delivered within next week! :cheers:
    Andreas
    Nov 2013
    24
    Yesterday I received my VF-2
    A couple of days ago we got a lot of snow, so luckily I had arranged for a proper truck to do the lifting
    And after a couple of hours in its final location:
    Nov 2006
    490
    Nice! Looks like the weather wasn't too bad., at least you have some pavement to use...
    Nov 2013
    24
    Machine is now up and running!
    Since I'm not at the workshop everyday I'm thinking of placing a circulation pump or two in the coolant tank to keep the coolant from going bad.
    How do you guys with machines in your home workshops do this?
    Nov 2006
    490
    I would say it's very dependent on the type of coolant, since some mixtures are made for long-life, whereas others aren't. There's also additives that can be used (anti-bacteria etc). You'll get a bajillion recommendations on coolants so that's kindof opening up a can of worms.
    That said, I do indeed run bubblers that in my tanks. I can't say that it's a make-and-break solution, but it definitely doesn't hurt anything.
    Nov 2013
    24
    Got Cimcool 620ff which should be a good long life alternative. I also put an aquarium pump in there (quite powerful..) to keep the coolant circulating while im not there.
    Gonna get a skimmer too.
    Machine is a beast! Nice hobby machine
    Congrats!
    I'm new to Haas. Looking at the picture it seems like the spindle is still in the from-factory shipping mount, any reason for that, like a storage thing, or is the install just not finished?
Page 1 of 2 12
  1. Design ready! But anxious about whether it's truly ready to build...
    By gamingan in forum DIY CNC Router Table Machines
    Last Post: 07-07-2017, 05:57 PM
  2. Ready to go!
    By cncadmin in forum EnRoute
    Last Post: 11-15-2012, 02:30 AM
  3. 0m not ready
    By f32cpe in forum Fanuc
    Last Post: 03-09-2009, 10:07 PM
  4. Taig CNC ready, how ready is that?
    By JB_in_Fla in forum Taig Mills / Lathes
    Last Post: 03-31-2008, 10:47 PM
  5. Getting ready to cut
    By landart in forum DIY CNC Router Table Machines
    Last Post: 08-27-2005, 04:10 PM
