586,065 active members*
4,795 visitors online*
Results 1 to 9 of 9
    Sep 2009
    135
    Torq Cut 22 Spindle Drive F-900
    Yaskawa 626VM3C
    I am getting a F-900 error on the spindle drive. Book says it is a Motor Thermal Error 1. Motor temperature exceeded upper limit.
    The machine has been idle for a few days so I know the motor is not over temperature.
    Any suggestions on which direction to head this time?
    Dec 2005
    504
    Re: Torq Cut 22 Spindle Drive F-900
    The motor has a thermocouple inside the wiring box if I recall. Check the wiring. Mine came loose one time.
    Sep 2009
    135
    When I put the ohmmeter on the thermocouple it shows open.
    Sent from my SM-G955U using Tapatalk
    Dec 2005
    504
    Quote Originally Posted by cooperjm View Post
    I believe it should show some resistance. I did some digging and found an old post that suggests it can be replaced with a 100 ohm resistor. YMMV.
    https://www.factorydaily.com/topics/...2-bridgeport-0
    I have a spare motor so I'll check it tomorrow evening and see what it reads.
    Sep 2009
    135
    I found that same post and tried it. It did not remedy the situation. I also work tried it without the resistor still did not work.
    Dec 2005
    504
    I should get home tomorrow early enough to check my spare spindle motor. I assume you checked continuity from the drive the motor?
    Does the motor start and then stop or simply display the error?
    Sep 2009
    135
    I can not enable the axis drives. As soon as I press 7 on the keyboard I get an Axis Drive fault.
    I did check continuity through the cable from the drive to the motor and that was good.
    Dec 2005
    504
    I measured the thermister on pins 11 & 12 (THSA & THSB) on my spare spindle motor, it reads 9.72k ohm. I'd try a 10k ohm resistor and see it it clears the error.
    Sep 2009
    135
    I tried a 100 and 1K resistor with out any change. Right now the Yaskawa drive is out for repair.
    Another thing I noticed is that there is only 0.12 volts between pins 11 and 12 coming from the drive.
    I will update this post when I get it back and running.
    Thank you for checking the restiance.
  1. Torq Cut 22 Spindle drive fault
    By cooperjm in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2018, 07:47 PM
  2. Torq Cut 22 Hard Drive question.
    By Steve_Watkins in forum Bridgeport / Hardinge Mills
    Last Post: 08-07-2017, 09:33 PM
  3. Torq Cut 22 Drive Overload
    Last Post: 07-16-2017, 03:53 AM
  4. Torq Cut 22 IDE to SD Drive & Win 98SE
    By Marty_Escarcega in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2016, 05:08 PM
  5. Bridgeport Torq-cut 22 forgets its hard drive
    By Alley-Way in forum Bridgeport / Hardinge Mills
    Last Post: 10-16-2016, 04:37 PM
