586,036 active members*
4,437 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Print call out confusion - M5x.8 ISO - H CLEAR
    Jan 2014
    32
    Photo attached. Can anyone tell me what
    M5x.8 ISO - H CLEAR
    5.3 DRILL (5.300) THRU -(4) HOLE
    Photo attached
    Dec 2013
    5717
    Re: Print call out confusion - M5x.8 ISO - H CLEAR
    I think it says drill 5.3 mm clearance hole for a M5x.8 screw. Fit class H (close). Normal clearance is 5.5mm for a 5mm screw.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    32
    That was a thought I had, was it was a clearance hole. I did forget to mention the following information was included in the notes when we got this job....(Tapped Holes: 4) see below.
    Notes:
    Material: Aluminum 6061-T6
    Standard Inspection
    Tapped Holes: 4
    FINISH: BEAD BLAST THEN BLACK ANODIZE
    Dec 2013
    5717
    Sounds like conflicting information, I would check with the customer to be sure.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    32
    Waiting on customer response. Unfortunately the part was already manufactured and "Failed Customer Inspection". I received a inspection report this morning and responded immediately. I reviewed the print and information and did some searching online and didn't find any direct information. I believe it to be a design/print error. We threaded the holes and the Failed Inspection report we received stated "M5 X .8 ISO - H CLEAR INSERT MISSING, PART THREAD INSTEAD"
    I'll update if any more info comes.
  1. Replies: 10
    Last Post: 04-03-2018, 01:34 AM
  2. Cam Confusion!
    By Mr Sprue in forum Uncategorised CAM Discussion
    Last Post: 02-22-2014, 06:24 AM
  3. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
  4. G52 confusion
    By davek in forum G-Code Programing
    Last Post: 09-08-2007, 02:01 PM
  5. confusion
    By serry in forum DIY CNC Router Table Machines
    Last Post: 04-28-2007, 12:40 AM
