586,077 active members*
3,793 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Charmilles Robofill 290, Wire breaks problem
Results 1 to 1 of 1
    Jun 2013
    Hello.
    I have a problem with wire breaking on the upper contact. The wire breaks off every 1 - 2 minutes of cutting. The machine is Charmilles Robofil 290 from 1996. Everything on the upper and lower head is fine. So I loaded the Autoiagnostic software into the machine and the CNC control passed everything but the Generator Chain failed. Error codes in the picture in the attachment. I checked the boards: UPR 1-4, RUPA 16, UPA 16, E / S, SAL + Restart, CCU PIL, CCU COM, PA + SA. These boards should be good (I changed boards from another working machine).
    Any ideas where the problem is? What should I check?
    Regards
    Paul
