586,058 active members*
4,019 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > diy parallel printer cable question
Results 1 to 5 of 5
    I can't find a male/male printer cable anywhere other than online. Trouble is, all my bits have arrived today and I want to get my Gecko up and running this weekend.
    I was lucky enough to be donated an old printer cable and bought a male DB25 assembly from Jaycar electronics. I've now successfully rewired the female end and checked continuity with a DMM.
    Here's my question; The Gecko manual describes pins 18-25 as "GND" but, although this printer cable has a jumper across pins 19 to 25, they're not actually 'grounded', just joined to each other. There is a conductor that connects the shell at one end to the shell at the other. Should pins 18-25 be grounded to the shell or am I right to go?
    Could someone please check their cable to see if there's continuity between these pins and the shell?
    Cheers in advance.
    Nov 2012
    1267
    Re: diy parallel printer cable question
    If the cable is shielded, solder the shield wire to the shell. If not, just leave the shell unconnected.
    35538
    I believe that in an actual printer port, the pins and shell are tired to the same ground.
    Mar 2007
    2083
    on a PC motherboard the printerport socket
    the metal shell & pins 18 to 25 are all connected together and
    via the ATX power supply black 0V wires to the mains supply earth / ground
    if you can only find a printer extension cable (f/m)
    you could of use a gender changer like this:-
    Attachment 402008
    https://cpc.farnell.com/multicomp/sp...xoCx1YQAvD_BwE
    to save changing the connector on your cable !
    some cheap printer cables don't have 25 wires inside
    so they connect terninals 18 to 25 together to use 1 wire instead of 8 !
    this is not a problem with the Gecko G540 or most breakout boards
    as long as a printerport ground pin (18 to 25) is connected to a G540 ground pin (18 to 25 )
    it will work
    as far as I remember
    the CNC4PC C10 breakout board is unusual
    pins 19 to 25 are all ground as expected
    but pin 18 is used to detect when the board connected to the PC printer port
    (or motion controller like the smooth stepper )
    John
    Thanks for the help guys.
    Cheers
  1. Parallel Cable
    By COMachineist in forum Benchtop Machines
    Last Post: 07-31-2014, 08:36 PM
  2. The Cable printer
    By cableprint in forum Other Machine Topics
    Last Post: 01-28-2014, 03:03 AM
  3. Parallel Printer Port Card!?
    By catabolic in forum CNC Machine Related Electronics
    Last Post: 05-23-2011, 02:15 PM
  4. anyone tried USB to Parallel cable?
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 05-12-2008, 01:09 AM
  5. Computer with no Parallel/Printer port?
    By SteveC68 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-17-2007, 12:35 AM
