586,082 active members*
3,613 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > blown spindel controller MBL-1100-300H
Results 1 to 6 of 6
    Nov 2009
    12
    Hello
    I have a Syil XP5.(from 2009). The servo controller of the spindel is out of order. The machine moves without the spindel controler.
    The print type: MBLC-1100-300H / 1100W/3500RPM/220V. I would like to substitute the blown part.
    I attached two picture and marked the blown part with a yellow pen. Is that a opto coupler? Does anybody know the type and maybe where to buy.
    Thanks a lot.
    Mar 2007
    2083
    Re: blown spindel controller MBL-1100-300H
    without the circuit diagram of the board and details of the part numbet of the burnt IC
    its going to take time to reverse engineer the board
    going by your photo
    Attachment 402086
    it looks like the burnt component is something like this VIPER12A :-
    Attachment 402088
    data sheet:-
    Attachment 402088
    or possibly KA7552A
    it will help to know the part numbers of the 4 parts arrowed
    Attachment 402090
    and to see a detailed photo of the underside of the board
    John
    Jun 2007
    3757
    Probably viper22a 8 pin switch mode controller.
    Almost any part of control wiring touching chassis can kill this device.
    Other parts mostly regulators, 5v, 6v? 12v. Maybe even 3.3v. Probably ok, if you are lucky
    Talk to you friendly syil agent! (chair)Best of luck.
    (wedge)
    Nov 2005
    222
    You could try MINI LATHE - MILL BOARD REPAIR SERVICE. I've used him a couple of times. Great service.
    John
    Nov 2009
    12
    On one side there are 4 connector and on the other side there are 3 conector.
    Attached a picture from the back side. I saw ooictures of other Syil spindel controler and they look pritty much the same.
    Attachment 402134
    Mar 2007
    2083
    seeing the photo of the under side of the PCB
    the TOP221-227 Family of three-terminal Off-line PWM Switches looks more like the IC used
    Attachment 402152
    Attachment 402154
    PDF data sheet
    Attachment 402156
    it looks like they have cut off pin 3 -
    one of the six source terminals to increase the insulation between the source and the control pin 4
    John
  1. Syil X4 with blown spindle controller
    By lockbuilder in forum Syil Products
    Last Post: 09-17-2018, 08:33 AM
  2. Replies: 5
    Last Post: 02-02-2016, 03:01 PM
  3. Spindel speed PWM controller
    By choelzen in forum CNC Machine Related Electronics
    Last Post: 07-28-2010, 06:07 PM
  4. cnc controller blown pcb trace
    By Mike7 in forum Controller & Computer Solutions
    Last Post: 11-06-2008, 09:54 PM
