586,409 active members*
3,014 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > fadal 4020 c.n.c spindle
Results 1 to 3 of 3
    May 2018
    dear sir,
    Hello
    i am mechanical maintenance engineer
    when i replace the bearing of spindle i need to know the correct an arrangement of 2 bearing at the bottom and the 2 bearing at the top of spindlr
    bearing number (7210 and 7012 )
    thank you sir
    Eng. Adel
    May 2006
    803
    Re: fadal 4020 c.n.c spindle
    First,
    do you have the correct tools to remove and replace these precision parts?
    Presses and plugs? Master Machinist available ?
    I am not sure how they are configured, but just put them back the way the old bearings came out. If you didn't look, likely I would change paths and buy a reman spindle. You need special tools, precision reloads and assembles in a clean room environment. Any contamination inside the spindle will spell a short life. FadalCNC.com has both new and reman spindles in stock at the best prices on the web.
    FadalCNC Tech Support
  1. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  2. Fadal 4020 - low spindle rpm
    By msmola in forum Fadal
    Last Post: 12-04-2015, 05:53 PM
  3. 4020 fadal spindle orientate failure
    By beekeeper in forum Fadal
    Last Post: 10-09-2010, 10:53 PM
  4. spindle orientation fadal 4020
    By atlantic23 in forum Fadal
    Last Post: 10-26-2009, 03:20 PM
  5. HELP ASAP with Fadal 4020 Spindle
    By TurboBlazerX in forum Fadal
    Last Post: 04-21-2009, 03:15 PM
