586,469 active members*
3,303 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > To ALL you Mazak & CNC programmers NEED your help
    Feb 2009
    13
    So my issues are we've started using CAM software to post a program. Problem is I cant use my Endmill diameter offset to increase the size of the holes, These are the G-Codes at the beginning of the program.
    G17 G20 G94 G40 G49 G80 G90 G94
    What should it be??
    ANY HELP would be appreciated.
    THANKS
    15362
    Re: To ALL you Mazak & CNC programmers NEED your help
    Quote Originally Posted by maddbomber View Post
    What should it be??
    THANKS
    It has nothing to do what is in the first line, the first line of code like this is referred to as a safety line, but you don't need G49 or G94 in there at all
    You can either make you tool diameter bigger or smaller in the tool selection and reprocess and have a new program
    Or use cutter comp which would be G41 and G42 depending if you are cutting left or right, and to cancel cutter comp you use a G40
    In Gibbs you just have to turn Cutter Comp On and then you process, you can then make your tool adjustments in the tool offset page of your control
    Mactec54
    Oct 2013
    12
    Did you solve yet? I could help you!
    I have VTC530C with mazatrol smooth G CNC software. (these one have a EIA/ISO tools-table and mazatrol tools-table).
    Dec 2009
    you have two g94
  1. CNC-PROGRAMMERS, OPERATORS and 3D
    By orolfsnes in forum Employment Opportunity
    Last Post: 09-13-2011, 03:50 AM
  2. Looking for CNC Programmers and Operators
    By cncjobs in forum Employment Opportunity
    Last Post: 09-12-2006, 07:30 PM
